Question about Makita 3 x 24" Belt Sander
Belt sander-belt coming off in use.
I have a brand new AEG hbs1000E belt sander. I have been using it to clean up strips of wood approx 1-2 inches wide. All was ok for a while but now the belt comes off sideways for no apparent reason! The belt is mounted in the correct way directionly and I have adjusted the tracking so the belt sits centrally on the rollers when in use. Surely this isn't normal?
  • 104 Answers
Have you tried adjusting the tracking slightly to the opposite side to which the belt comes off this has worked for me on my Bosch
Posted on May 23, 2009
Manual dayton # 2z646b belt sander 1" belt/8" disc sander
You can use Wen 4 x 6 inches belt/disc combo sander. Easy to use and the price is so cheap. More details Practical WEN 6502 Sander Review For Improved Sanding Skills
Feb 11, 2013 | Tools & Hardware - Others
How to clean a clogged belt sander
I assume you mean you want to clean the belt itself? You can use a rubber stick made for this. It looks and smells like a giant pencil eraser, about 1 inch square and about 10 inches long. However, if the belt is clogged with melted paint, that won't do much - but a stiff wire brush works OK. If the wire brush doesn't work, get a new belt. You can avoid the melted paint buildup (or at least reduce it) if you keep the sander moving rapidly over the surface, and use a good quality scraper to remove as much paint as possible before sanding.
Sep 19, 2012 | Makita 9404 4'' x 24'' Belt Sander
I am sanding down oak boards that i have laminated together for a bar top. no matter what grade of belt i use or how careful i am it is leaving lots of ridges in the wood. never had this happen before
Belt sanders are not good for finish sanding because they will leave ridges, but they are great for removing lots of wood fast and getting you roughed in. Use the belt sande to get your work fairly level then switch to a palm sander to get it smoothed out.
Feb 09, 2011 | Makita 9404 4'' x 24'' Belt Sander
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Just stopped turning, motor still running though
I take it that the rear drum stopped turning and if so the drive belt or one if the pulleys could be your problem. I would be doubtful if the gears are stripped. Give me the model number and brand and I will find a schematic for you. If this is the Porter Cable sander. on the side with the black cover you will find 3 screws that you can remove, UNPLUG tool first and take a quick look to maybe find your problem. Let me know if I can help further
Aug 09, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
New belts on drum sander shear off inside clip
Belt sander are very tempermentel and require a light machine oil (3-in-one) on the metal slides and Tension lever and springs to opperate properally, if not they will drive you nuts, it will make a big differance, a few drops will do ya, more it needed, to much will cause a reverse action and collect dust, clean areas before oiling with air preasure and fluids if needed to get rid of build up from wood dust
Jan 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Motor runs but the drive drum that hold the sanding belt does not turn.
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Oct 27, 2008 | Dewalt Factory-Reconditioned DeWalt DW432R...
Wood working sander?
belt because it work realy good use ing the circle scraches the wood and the beld dos not
Sep 28, 2008 | Milwaukee Tool Milwaukee 6125 Sander Ro 5...
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Makita 3 x 24" Belt Sander Logo
810 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
