Question about Canon PIXMA iP90 Mobile Printer
The printer keep informing that the colour ink not replaced.
I've tried to change the head printer and still the problem still persist as above. I have so many packets of ink both black and colour. I have misplaced the software and how can I get to software for the pixma ip 90.
  • 92 Answers
There could be 2 reason for this problem. Either the ink tank is not installed correctly or the printer need to be reset. Follow the below steps which might help you resolve the issue:
STEP 1: Check the Ink Tank
If the ink tanks are not locked into place, ink will not be supplied to the print head.
  1. Turn the printer on.
  2. Check that the printer is powered on and open the printer cover. (The print head will move from the right to the center.)
  3. Confirm that the ink tanks are installed properly.
    Example: Ink Tanks installed correctly.
    Example: Color Ink Tank instthe printer keep informing that the colour ink not - ip90tanksnotok.gif
  4. Press down on the Puthe printer keep informing that the colour ink not - krik.gifon the ink tank to lock the ink tank into the allocated slot of the print head.
    Note: Pthe printer keep informing that the colour ink not - ip90tankorder.gif until a click sound is made.
  5. Install the ink tanks in the order shown below.
  6. Close the printer cover.
STEP 2: Rest the printer
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If the above 2 steps does not resolve the issue, you printer might require a repair.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 26, 2009
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
Jun 13, 2013 | HP OfficeJet V40 All-In-One InkJet Printer
I replaced the blue ink cartridge and now all colors look blue.
You say all colours look blue? If this is true, does black look blue? If so then black is not printing at all so blue takes over. Did this machine print colours ok before you changed cyan? I would suspect that you are using compatable ink cartridges and they are suspect. check that all the cartridges are in the correct positions. Then run the cleaning cycle and see what happens. If the problem still persists then I would change the print head. The print head part number is QY6-0073-000.
Good luck
Apr 23, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Colour ink not printing - just black
Try to clen the print head,go in the driver of the printer,next maintenance and clean the print head.If the problem persist you need to replace the print head.The print head is under the cartridge.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Canon PIXMA MP750 All-In-One InkJet...
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
Printer won't recognise new colour cartridge
I got a new print head @ "staples" office supplies. It didnt cost me anything!!! Kodak had probs with the head, & gave a bunch to staples.....i changed the head, put in new inks, again...got a calibration to run...& things printed np!!!
Apr 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP 2600N LASER PRINTER
You can try going into your print settings/preferences and checking magenta only. printers you need to keep a watchful eye on your ink levels, because if you are out of ink, you can not print in ANY color, even black.
If the above thing not works You can begin by making sure you are not using anything above 24-bit colour (RGB) in Word.
Also: Word does not use a colour profile. It doesn't make any changes to
the colour, so it doesn't compensate at all. The only colour profile
between Word and the printer is your Printer's colour profile.
Hope this helps
Sep 19, 2008 | HP Color LaserJet 2600n Printer
Canon PIXMA iP90 Mobile Printer Logo
130 people viewed this question
old marine
old marine
