It only plays half of the song
My Coby MP-C582 MP3 Player, only plays have the song before skipping to the next one or cutting out completely and I have completely run out of ideas. So, any thoughts about what I should do?
    Problem Solver:
  • 9 Answers
NTFS problem format
If doesnt help then flaw in the memory chip
send for service
Posted on Apr 19, 2009
I have a coby mp-c582 that I bought used for my grandson. I like it fine but am not completely sure of what each button does. The o and x button on the side for instance. What is that one for. I thought it...
You are confused because the buttons have several purposes. The +/- are volume up and down and Next/Previous. If you press and hold the button, you control the volume. Quickly press and release for Next or Previous. The button below them is Pause/Play and Power (again press and hold to power on or off). The switches on the left side are Hold (no buttons work) and Random (play loaded songs in a randomized order)
For the hold feature, move the switch to the padlock. Unlock by sliding the other way. The Random switch has a more obvious label - Random or Normal.
The user's manual for the MP-C582 is available here: http://www.cobyusa.com/files/manuals/MPC582_MN.pdf . If the direct link doesn't work, try the support site: http://www.cobyusa.com/?p=doc and search for the model (MP3 & Portable, MP3&MP4 Players, MPC582.)
I hope this helps.
Feb 24, 2011 | Coby MP-C582 MP3 Player
Reset the device and charge again. You will lose the data but the drive should work. If that doesn't work it may be the battery.
Thanks,
Feb 19, 2009 | Coby MP-C582 MP3 Player
Operating
pretty simple.
BUTTONS:
>|| : Play/pause. press to play/pause. press and hold to power on
+ : Plus. press to go to next song, press and hold to increase volume
- : Minus. press to go to prev song. press and hold to decrese volume
LOCK switch: locks buttons, prevents loading/erasing songs
SHUFF/NORMAL switch: switches between normal and random playback
that's about it
Jul 23, 2008 | Coby MP-C582 MP3 Player
Red Light Stays On.
i think that you need to let it charge ,& then try to play it ,or try to shuffle the music after you install it
Jun 26, 2008 | Coby MP-C582 MP3 Player
Coby MP-C582 MP3 player
make sure what your putting on is MP3 or unprotected WMA files. If the light is blinking, then it means its playing the song, if you hear nothing, the audio is not in the correct format.
May 03, 2008 | Coby MP-C582 MP3 Player
Help with copying music to my mp3
I have the same player. Are you just dragging and dropping songs on to the player? I use Windows Media Player 10 to put music on the player. It has a function called SYNC. What that does is take your music from WMA 10 (WMA, MP3 files, etc...) and transfers them to your mp3 player. You might give that a shot. Also, WMA 10 should recognize your player and let you connect with it.
Feb 16, 2008 | Coby MP-C582 MP3 Player
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Trying to remove
While connected to your PC browse to the folder on the Coby which contains your MP3 files. Delete the songs you no longer want or cut and move them onto your PC hard drive.
Dec 29, 2007 | Coby MP-C582 MP3 Player
Itunes
No, the Coby MP-C582 clip mp3 player only supports WMA and MP3 playback, iTunes uses AAC
Dec 25, 2007 | Coby MP-C582 MP3 Player
Coby MP-C582 Will not turn on
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
56 people viewed this question
 Grubhead
Grubhead
