Question about Tomtom ONE 3rd Edition GPS
When I bought my sat nav Tom Tom version 3 it worked fine. The second time I used it I now cannot pick up a GPS signal at all. Tried Reset and a Factory reset. Can any help?
  • Anonymous Apr 22, 2009
    it was working fine all of a sudden it dropped the signal. i was in a place on a highway with perfect reception that always recieves a signal. it just stopped. now i have traveled to three other states since then and it never was able to pick up a signal even 3 states away and back home again it will not pick up a signal no more.
  • especial1964 Apr 28, 2009
    lost signal tried everthing reset, connected to computer lost signal 2 days ago,
  • 39 Answers
Move the receiver to a different part of ther car if your car's windscreen is coated windscreen
Posted on Apr 20, 2009
Tom tom one sat nav sound not working
Hello there,
First of all, what you need to do is to reset the device. To reset the device fold a paper clip and use it to hold down the reset button for about 5 seconds. The tomtom tom will be reset. Then you power it on, then go to settings, then you select the sounds, then turn on the sound. And increase the volume.
The sound will work perfectly fine after doing this.
All the best. Elect_Comp
Sep 03, 2011 | GPS
How can i update my guide sat nav
If the maps are on an sd card you may be able to put tom tom on but as for updates myguide no longer exist and so don't provide updates. Mine still works fine and any roads that have been built that don't appear on the sat nav i have managed anyway.
Mar 18, 2010 | MyGuide 3100 GPS Receiver
Sat nav just stopped working today in perth wa, not picking up any sat signal. any way to fix this? is it my sat nav or the sats?
It isn't the sats. They're fine.
Try resetting the unit. Use a paper clip to press the button in a small hole on the bottom.
Try to reset the sats. To do this:
Tap the satellite bars in the lower right-hand corner.
Then, on the next screen, tap the satellite bars in the right-hand margin.
On the next screen, select "Configure." Choose a different configuration. Tap "Done," then "Done" again on the next screen.
Did that help?
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
MY TOM TOM WILL NOT START
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
Sep 21, 2009 | Tomtom One XL GPS Receiver
Tomtom one sat nav 18 months old is now taking upto 5 minutes to get a gps signal. When desination is entered the calculation is done tap done and continue then it says gps signal was lost and takes...
try downloading tom tom home to your computer and use your dock or cable to connect it to your computer, switch on your tomtom and allow it to connect to your computer and updates should automatically happen, this should fix it, good luck
Aug 26, 2009 | Tomtom One XL GPS Receiver
My tom tom cannot track its GPS and the screen freezes
My tomtom one screen kept showing that it was waiting for a valid gps signal all day yesterday 7/1/09 what can I do to fix this problem?
Jul 02, 2009 | Tomtom GO GPS Receiver
Tom Tom sat nav takes ages to get a GPS signal now.
Think I have sorted the problem out. I read some of your readers' solutions and it was mentioned that it may be advisable to log onto the GPS update. So, I installed my disc which came with the pack and followed the instructions to download the GPS update (and also took the opportunity to download other updates which took some time). Anyway, used the sat nav this morning and so far, it appears to be working normally now and the signal comes on in seconds!
Jun 23, 2009 | Tomtom ONE XL GPS
TomTom One GPS fault
I had the same problem after downloading the latest maps, the unit was slow to boot up and would not find any satelites. I had no response from e-mails to Tom tom tech support and I was going to give up and buy a new device if this fix failed. I had tried paper clip resets and resetting to factory settings but they had not worked.
After reading the previous answer to this link I searched Tom tom support for 'clear flash' and the search results were more useful than the FAQ on the normal support pages.
I used Tom tom home to uninstall the current software application and then reinstalled the latest version (I had to go through several updates as my version of the software was from when I purchased the unit in 2007), I then downloaded and ran Clear flash and made sure that I disconnected the tom tom from my PC using the correct procedure (using the eject button in the bottom of the tom tom home screen as I read that this could have contributed to the problem in the first place).
After another reset the device came to life and after a few minutes searching for satelites outside the device worked as it should (try checking the configure GPS option if it is taking a while to find a signal, it could be just me but it seems to speed up the search process).
Hope this helps.
Apr 07, 2009 | Tomtom ONE XLS Car GPS Receiver
My tom tom is not picking up gps signal
I just connected to my computer and ran updates that I got from tomtom.com... It works fine now. Try it with the new software.
Oct 16, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
221 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
