Question about Optics
Swiss arms 4 x 40 reticle broken
I own a swiss arms 4 x 40 scope ive only had it for about a month and th orher day i noticed the horizontal crosshair line has saperated for the others and i thought i could still shoot it with three lines so when i shot it the others separated
I managed to fix a scope with a broke retical by replacing the wire with a piece of fine hair glued to the edges of the retical ring.
The scope must be disassembled taking care not to ruin the threads, scratch the glass, etc. It's easy to make a mistake and reverse the optics when reassembling, so take care to note the direction of the glass.
My retical was mounted on a metal ring, it was made of fine wire, and soldered onto the ring. I used a tiny drop of JB weld to glue the hair to the ring.
If I had to do it all over again, I would have looked for something finer than hair... And made a jig to clamp the hair before gluing.
(it took me several attempts to get it just right.)
Posted on Apr 28, 2009
Good day my is Wade my Swiss Arms air rifle has got no power when shooting.
there is no air rifle suitable for south african hunting conditions.
Sep 09, 2016 | The Optics
How to repalce the crosshairs
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Jan 23, 2013 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
The paint has been chaffed off from being pulled in and out of a gun bag. What product can I use to recoat my scope
You can rattle can it, but the spray nozzle is course compared to the factory finish. You might even try a can of gun blue, walmart has it, g96 brand works good, rub it on then spray it with wd40 to oi it up and polish it.Or you can check out this guy on ebay,
Broken Scope Crosshair Repair
Mar 14, 2010 | Tasco RIMFIRE SCOPES BLACK GLOSS...
I have a Busnell Scope 3-9x40 73-3940S
If the reticle doesn't move at all, you've got a damaged scope. Don't bother to take it to anyone to repair, just send it in to Bushnell and have them repair it. Hope this helps, Mark the Gunsmith
Contact info below: United States
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734
Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Canada
Bushnell Corporation of Canada
25A East Pearce St.
Richmond Hill, Ontario L4B 2M9
Local Phone - (905) 771-2980
Other - (800) 361-5702
Local Fax - (905) 771-2984
Other Fax - (800) 661-3254
Dec 09, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I have a Redfield 'LO-PRO' rifle scope, 3X9 variable, on my 300 Win Mag. It is about 20 to 25 years old and the cross hairs must be loose. They are not straight up and down anymore. Will this affect the...
It doesn't sound like anything's broken, it sounds like the scope has shifted in the rings, as you said "they are not straight up and down anymore", which won't effect your accuracy at short ranges, but if there's long ranges (more than 100 yards) you're going to be off some.
You can loosen the ring screws until the scope will turn, either 2 or 4 screws that hold the two halves of the ring together. There are numerous tools to help you align the crosshairs, but when I do this job I just square-up the reticle (crosshairs) by looking at the center of the reticles and let your eye follow the bottom crosshair down and make sure it is centered on the back of the bolt or receiver. If you need help doing this job, take it to your local gunsmith, he'll be able to square these up for you and boresight it.
Dec 09, 2009 | Optics
I need the cross hair adjusting screw cover
Go to a gunshop that deals in tasco scopes and they should be able to see you right.
Aug 15, 2009 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Windage and elevation not working barska 8-32*50mm
I doubt if there is anything wrong with your scope.
The Baraska model A10810 Reticle adjustments are 1/8 ( 1/8 inch) MOA (minute of angle).
For instance, Look at the top turret (The ELEVATION Adjustment Knob). You will see that there are little vertical 'hashmarks' all the way around the knob starting with a '0' then a series of the verticle hashmarks, then a '1' and another series of the marks, then a '2' and so on. YOUR scope will have 8 of those vertical 'hashmarks' between each 'number'. These little 'hashmarks are referred to as 'Clicks' or 'Minute of Angle' adjustments.
Now imagine that you are set up on the 100 yard line and you have fired a round at your target, say a one inch diameter dot or any size for that matter, and the bullet strike was one (1) inch LOW and two (2) inches to the RIGHT and of course you now want your next round to impact in the target dot.
To bring your bullets point of impact UP to coincide with your point of aim (you have your 'crosshairs or RETICLES centered on the dot), you will be turning the TOP adjustment knob CLOCKWISE, ONE 'click' at a time. EACH one of those 'Clicks' will actually move the horizontal Reticle UP (Elevation) or DOWN 1/8 of an inch at a time. If the bullets point of impact was 1 inch LOW, you would need to turn the adjustment knob clockwise Eight (8) clicks which will equal ONE (1) inch.
Now you must adjust the knob on the RIGHT side of the scope. This one is the WINDAGE Adjustment knob which controls the VERTICAL Reticle and moves the point of impact Right or Left. This knob will also have the 'hashmark' increments around its perimeter and like the Elevation knob each 'Click' will move the Reticle 1/8 of an inch but in this case the Reticle and point of impact moves Right or Left.
Remember the bullets point of impact was 2 inches to the RIGHT. This means you must adjust the Reticle or point of impact to the LEFT so that your point of impact will coincide with your point of aim and will be in the target dot. Turn the adjustment knob COUNTER CLOCKWISE Sixteen (16) Clicks. Keeping your POINT of AIM (crosshairs centered on the dot), your next round should be inside the dot and you can then fine tune it from there.
As you can see from this example, the Reticle (crosshairs)and point of impact does not travel very far at all inside your scope at the 100 yard distance so it is not hard to imagine that you thought they were not adjusting to get you on target, when in fact they WERE adjusting, but in tiny increments.
Now, as you create more distance between you and your target, these 'tiny' increments and point of impact will be larger as your distance increases. For example, at 200 YARDS each 'click' will move your Point Of Impact 1/4 of an inch right,left,up, or down. So if your bullet point of impact was one (1) inch low from the 200 yd line you would adjust your Elevation Reticle 4 Clicks to raise your point of impact in order to be on target. At the 300 yd line each Click will adjust the point of impact up,down,right or left, ONE (1) inch.
If you wish, I would be happy to walk you through the 'ZEROing In' of your scope and rifle even if you do not have a Zero Bore Scope. With-in about 9 rounds you can be hitting where you are aiming instead of 'chasing' bullet holes all over the paper.
If you are interested, respond back and I will be glad to assist you. Enjoy. :)
Apr 07, 2009 | Optics
A piece of lint has fallen across the crosshairs on the left side
Have you tried either a throttled down vacuum or a can of air (spray)?
Mar 27, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
NEED REPLACEMENT PART FOR TASCO 4X15 I NEED THE CROSSHAIR PIECE
im sorry but the price of that scope is not worth getting new crosshairs, you should just go get a new scope at walmart. they are like 9 bucks. But i myself would get a better scope, you can get decent ones for liek 60 bucks. Last a lifetime if you take care of them. The best scopes can cost 800 dollars on up. Just get a new scope. the part would coast more then the scope.
Dec 13, 2008 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Optics Logo
474 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
