Question about Samsung SCX-4100 All-In-One Laser Printer
Error Message My Printer is giving me an error message saying Paper Seection Error. Brother M4318
  • 10 more comments
  • Anonymous Nov 27, 2007
    my epson LX-300+ is sending error printing
  • dave44 Dec 12, 2007
    imagerunner 1023 error E197
  • lesley9 Feb 02, 2008
    Printer says put in paper---There IS paper dammit!!!!
  • Anonymous Feb 18, 2008
    paper error message
    "turn off printer for 10 seconds"
    still doesn't work
  • Anonymous May 06, 2008
    Same problem with the Zebra Z4M
  • writer33 May 19, 2008
    My Canon BJC 55 InkJet Printer keeps saying I have no paper in it. I do but still get error message - any ideas? I have turned it off, reloaded paper, turned it on many times no luck yet.
  • sapir huberman
    sapir huberman Jun 24, 2008
    it happens to me too.
  • dianainanna Aug 03, 2008
    When I turn on my printer it displays an error message and the orange light flashes beside check paper...I have loaded more paper and pushed cancel...it will run back and forth real hard then the orange light will start flashing again...what can I do?
  • samsang12 Sep 11, 2008
    open heat error in samsung scx-4100
    open heat error
  • Anonymous Oct 21, 2008
    Large E and at side of pages sign and red light flashing above?
    wont print anything and have follwed instructions on hp troubleshooter
  • Anonymous Feb 09, 2009
    canon 390 multipass prints every other line...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Posted on Mar 02, 2009
My printer showing
open heat error
Posted on Mar 17, 2008
Banking error how to solve this problem
my printer not working
Posted on Nov 26, 2007
2 Suggested Answers
SOURCE:
Dyes
  • 6 Answers
SOURCE: Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Posted on Aug 15, 2008
I have to print out a paper right away, could you help me?
If it still prints ignore it.
if you rather call the vendor. Ifyou're under warranty. They may replace or repair it.
Apr 18, 2015 | Brother MFC-7220 All-In-One Laser Printer
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
My brother printer mfc-j415w keeps giving me an error message which says paper jammed, I removed all paper and bits of debris found in between the rollers but it still keeps giving me the same error m
there will be paper to the side of the printer which is stopping the carriage from travelling fully which will also be why it makes a noise.
If its to the right of the carriage, start printer and when carriage starts to move pull the power lead, you'll be able to move the carriage out of the way and look in with a torch to find the paper or foreign object. Just remove it and restart the printer and everything will be normal.
Please indicate if it fixed your problem here.
If you need ink for this printer go to our site:
http://www.the-inkstore.co.uk
Jan 29, 2013 | Office Equipment & Supplies
I had a paper jam, got the paper out but it keeps saying paper jam.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Feb 24, 2011 | Brother MFC-465CN InkJet Printer
Error saying the back cover is open but it is not. We have tried reclosing and cycling power.
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 16, 2011 | Brother MFC 7420 All-In-One Laser Printer
Says paper jam but is not does'nt feed paper
Oct 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
Error Message
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
Samsung SCX-4100 All-In-One Laser Printer Logo
1,395 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
