Question about Patio Classic Grilling
I need cast iron burners for nz400s patio classic
4 Suggested Answers
Kgt1962
  • 59 Answers
SOURCE: burner replacement
If you ermove the control panel on the fom you should be able to slide the gas manifold back a little thus putting the nozzle into the burners.
The manifold has a couple of screws at the sides
Posted on Mar 05, 2009
SOURCE: Jenn Air gas grill with cast iron burners...only
It sounds like your cross-over **** located underneath on the back of the burner is needs cleaning. Take your burner out, turn them over and your will see a slot on the rear of the burner. wire brush the slot until it has a clean ****. This cross-over **** is what brings the flame to the right side.
Posted on Apr 27, 2009
  • 11 Answers
SOURCE: Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Posted on Nov 02, 2009
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
I am having trouble finding a burner for my Patio Classic Gas Grill Model : NX400! Can you please help me find one?
Unfortunately, your model Patio Classics Grill has been discontinued by the manufacturer. However, many manufacturers use the same type burner and those can be used on your grill. All you have to do, is compare your old burner (shape, size & length) to one of theirs. I have included a link to an online grill parts store that stocks hundreds of burners. I am sure you will be able to find one that matches yours there.
http://www.grillstuff.com/gas-grill-burners/?cat=48
Good luck & Happy Grilling!
Mar 28, 2011 | Patio Classic NZ-400-S Grill
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
Jun 11, 2017 | Viking Grilling
My burners don't put out out much of a flame. Model CGBD48RSBX. Ten years old. Can I clean them?
That depends, Are the burners stainless steel or cast iron? The cast iron burners are heavy duty and can usually be cleaned, but the stainless kind may just fall apart after a few years of usage. It just may have clogged burner holes from rust and drippings that can simply be wire brushed. I'd use an air compressor to blow out debris from inside the burner as well.
May 12, 2010 | Grilling
I need to purchase a new oil boiler. which is better with hard water,, cast iron or steel. or is there no problem with either
i am told that with time the cast iron boiler will have problems due to the ph of the hard water, therefore the steel boiler is recommended.
Nov 18, 2009 | SySTOR Systems (400S52) Burner
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
H Burner replacement
There are aftermarket cast iron burners available for approx $64.95. Otherwise, the OEM burner is a Dynachrome which is a chrome plated cast iron that is almost $300. I do not believe that the cast stainless is still available.
Jul 26, 2017 | Dynasty Grilling
Grilling Logo
Top Patio Classic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Patio Classic Grilling Expert? Answer questions, earn points and help others
