SOURCE: My superstar 3900 transmits on one channel and receives on one ch
Ok! well i deffinitally know what the problem is. You need to play with the clarifier, i think all the way to the left is a "course and fine tune" knob. This is generally for use when talking on SSB. but may affect AM if its way off.
The clarifier lets you slide on the freq. some radios will go a full channel some will only go a little or above the center of the channel. You need to play with the clarifier, you probably need to turn the course a lot, untill the audio is almost clear on the channel you want to talk on, than use the fine to tune it in so it sounds like they are sitting right next to you.
what you should do is buy a Frequency counter, you got a nice radio, so the freq. counter wouldent hurt. lets say you want to be on channel 19. you would turn the clarifiers untill i read 27.1850 That would put you right on the money
SOURCE: what chanel are what
D is your basic 40 channel, this is what most truckers talk on, then C is low, b is double low and a triple low then e is high and f is double high, this radio also has upper and lower side band, most ham operators use these channels. Hope its been convered to talk on CB band.
SOURCE: whats the wiring diagram to connect a sadelta
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
SOURCE: a need help on my superstar 3900 the signal meter
The FM has no forward modulation. You're radio will key up but you can't transmit on it. All cb radio are like that after conversion.
