Question about ASUS P4P800SE Motherboard
Won't start up
When I turn on my computer. sometime it goes to the BIOS start up screen and just sits there. if I leave it,it may start up in 10 minutes.
the same happens if I hit delete to get in the bios to check if my setting are there.
Manufacturer : ASUSTeK Computer Inc.
Product Name : P4P800SE
Version : Rev 2.xx
63-0703-000000-00101111-100104-I865PE
| | | Chipset/BIOS Info
| | BIOS Build Date
| Manufacturer ID
BIOS ROM Information
  • Anonymous Apr 19, 2009
    sma as above
    Problem Solver:
  • 19 Answers
When your computer it should say f1 to stup if you go into to the setup menu and scroll around untill you find bios and if you are going to use it dont turn it off if you are not going to use the bios it will help your computer if you turn that off rate me thanx
Posted on Apr 19, 2009
2 Suggested Answers
herminio_hal
  • 210 Answers
SOURCE: startup stops ---P4P800SE
Hi turn off an unplug the PC open the right side cover of the computer, remove the memory card and clean the contact cotton w/alcohol and wipe it dry and re install it back. This might solve the problem.
HH
Posted on Sep 05, 2009
Windows 7 won't load
try going to the bios screen and re installing the windows
Jan 31, 2013 | Acer Aspire One PC Notebook
ASRock motherboard AliveNF6P-VSTA----Every day when I try to switch on my PC it won't start. Than, after about 10 attempts it swirtch on normally!
Hi, The least thing would be a faulty on/off switch, otherwise it needs setting up better in the BIOS & if you don't know what your doing you can scrap your computer really easy, The best thing is go to PC shop it should not cost very much £25 max to reset the BIOS. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | Computers & Internet
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
My acer aspire 2920 goes black screen when I try to boot Ubuntu from USB. I thinking of reset the bios. Please help me with the procedures
Hi there. It won't be a bios problem if it allows you to selet the usb to boot from. Sometimes when you try to boot ubuntu off of a usb it gives you a black screen for as long as 2+ minutes. usb drives can be slow but if it still will not boot then it is likely a problem with the boot loader on the usb stick. I would try installing ubuntu to the usb again to see if it works. If it still won't work then there is more than one way to install ubuntu to a usb. Leave a comnent here if you still can't get it to work and i can give you some more instructions of how to make it work. It shouldn't be a problem with your computer though.
Sep 14, 2011 | Acer Aspire 9300 Notebook
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
HP a1600n desktop will turn on but will not boot. Does not run thru BIOS, keys/mouse check. HDD spins up, CDROM goes thru check then just sits. Monitor doesn't kick in because doesn't get to video check....
you need to open up the case, and remove the CMOS battery ( a silver wafer-style battery about the size of a quarter) and leave it out for about 10 minutes. put the battery back in and close the case back up and DONT mess with ANYTHING ELSE. if the computer STILL wont boot, then your motherboard is bad, and will need to be replaced through the manufacturer of your PC.
Sep 24, 2009 | HP Pavilion a1600n (882780776265) PC...
Startup stops ---P4P800SE
HH
Apr 18, 2009 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800SE Motherboard Logo
263 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
