Question about IBM ThinkPad 380ED
Thinkpad 380ed Error 00161 & 00163 cannot boot how to fix it ? Regards JMA
  • 3 more comments
  • JM Aubin Sep 19, 2007
    did change batterie RTC
  • crai1727 Dec 02, 2007
    i have IBM labtop 380ED. there is a start up problem and it says error 00161 and error 00163. then i enter the date and time then it just restarts. holding F1 down does not work. does anyone now what i can do to fix it?
  • Anonymous Dec 11, 2007
    error 00161 00163 ibm 380ed...tried holding the f1 key while off etc etc etc still starting up showing same error messages....cant rectify, any help appreciated.
    Rgds Steve
    iv set time date etc and still same 00161 & 00163 error message showing...iv even taken the battery out, replaced & the time & date have stayed set to correct but still same errors??
  • maddav68 Mar 22, 2009
    thinkpad 380ed ,starts up until the IBM logo appears then shuts off,any suggestions ?
  • 3 Answers
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Posted on May 04, 2008
Hi guys thankyou for your help, ive changed the battery and it worked perfectly
Posted on May 10, 2009
Throw it away and go with an apple
Posted on Feb 24, 2008
    Scholar:
  • 181 Answers
Hi, Error 161 and 163 is time and date not set in bios. In other words, it's likely the cmos battery is probably weak or dead (although it should show an error 192) Just press F1 and access bios, set date and time, leaving the ac adapter plugged in, restart the system. It should boot. Good luck
Posted on Sep 19, 2007
  • 89 Answers
Go to IBM web site and get the latest BIOS update for your laptop. Try a BIOS update. If the BIOS updqate does not fix the problem - you will need a new motherboard. We have had this problem before in our repair shop. It is very frustrating. Don't expect a great deal of help from IBM tech support. Wish I had better news for you. Good Luck.
I changed the battery and problem was solved :) thanks
Posted on May 20, 2008
Changing the batterie did fixed the problem for me
JMA
Posted on Feb 13, 2008
Me to the same errors
Dupa
Posted on Feb 10, 2008
Iv set time date etc and still same 00161 & 00163 error message showing...iv even taken the battery out, replaced & the time & date have stayed set to correct but still same errors??
Posted on Dec 11, 2007
Error code 161 ? ibm 380ed
you have not give us the detail problem, when/where you are getting this error?
Apr 01, 2010 | IBM ThinkPad 380ED
My IBM think Pad shows error I9990-305 what is it
That is a MBR or Master Boot Record error. Sounds like you may be running win 98 or ME. Basically, you need to re-install windows.
Oct 22, 2009 | IBM ThinkPad 380ED
Unable to boot and memory data error
under the keyboard there is a battery while the laptop is off power try to remove it for 5 minutes then reinstall it , then try to boot , if u get stuck again then u have to change the faulty ram module
Aug 07, 2009 | IBM ThinkPad 380ED
IBM Thinkpad 380ED Startup Problems
its the small battery that is dead, if you open the ram on the underside there is a small battery under the ram chip, yours is dead cause i had the same problem.
Nov 04, 2008 | IBM ThinkPad 380ED
IBM THINKPAD 2635-5AA 380ED ERROR 174
Your problem sounds like the system isn't finding the hard disk
May 01, 2008 | IBM ThinkPad 380ED
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
174 error message on thinkpad 380
00174 usually means a bad drive/hard drive/or controller for the drives Try replacing the hard drive.
Dec 09, 2007 | IBM ThinkPad 380ED
IBM ThinkPad 380ED Logo
2,678 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
