Question about Frymaster Dean H17-SC Deep Fryer
Y have difference of 70 degree less in oil at the computer and the temperature probe its new ex:at 350 setting ,the oil is 280 f
    Novelist:
  • 125 Answers
Hello. Usually the problem lies in the wiring to/from the probe, the connection points, or the interface board, and I have even seen the harness between the computer and interface board have a problem. The probe has a specific resistance at a specific temperature, so cause resistance anywhere in the circuit, and you now have a different reading on the computer, or so it thinks. I hope you used a pin pusher, and didn't cut/wire nut the probe wires, because you just added a lot of resistance to the circuit. The probe should read 1654 ohms at 350 deg., but your only getting 280 deg. so, the probe would be 1514 ohms.
I have no way of knowing at this point if you have the old interface board, or the new, so I will give you the pin test points for the new one, disconnect your computer, and on the relay board, there will be 12 points with a label for J2, pins 11 & 12 should be for the probe, from the back to there. If the readings are not correct to that point, then you have wiring, or problem with the interface board, if they are, then the interface cable to computer, or the computer.
You can go to www.frymaster.com, download a service manual, and do some snooping, but they don't tell you everything, like those resistances.
Hope that helped, and thank you.
If you need further help, "ask me"
Posted on Apr 20, 2009
We have a 2-year old Viking gas range (model VGCC5304BCC) and lately the oven temperature has beeen running about 25-40 degrees higher than the selected temperature. I cannot find a way to calibrate or...
use a digital thermometer with a probe inside the cavity, normal preheat is 30 mins to 350, wait until the 3rd cycle to see what temps are in the cycle, record high , low temps add and divide. plus or minus 10 are in scope. ex 350 on at 340 off at 360 will avg 350. depending on the serial and age, there is no calibration unless your Electronic thermostat would be suspect. Hope this helps.
Sep 29, 2013 | Kitchen Ranges
The oven doesn't come close to keeping a REASONABLE temperature. It fluctuates sometimes 75-100 degrees. I'm not talking about opening the door and then waiting to re-establish the temperature it was set...
If you just bought it, have it replaced, or repaired under warranty. If it is an old oven, replace the temp probe first (if it electric) It senses the temp inside oven, It is the least expensive part of the fix. If that doesn't work, replace thermostat/temp control board. When you replace a board, you replace the probe too. It will be needed either way. If just changing the probe works, you saved yourself some money.
Apr 06, 2010 | Kitchen Ranges
When we set the temperature on the oven, say 350, it will heatup over 400 - 450 degrees. Is there some way to regulate this problem?
Hi.
If the temperature runaways 50 or 100 degrees over the set temperature, then you probably have a defective temperature sensor. Replace the temperature probe located inside the oven cavity, that should fix the problem. If it does not, then the electronic control is defective, but that is not commonly causing this conditions.
Regards.
Mar 05, 2010 | Amana Ovens
My oven does not hold the temperature or sometimes it shoots up to 400 degrees when set for 350 degrees. can it be fixed or do I need a new range?
Hi.
It can be fixed.
The part that is most commonly causing the problem is the temperature sensor.
When the problem is the temperature probe, both baking and broiling functions are affected.
Regards.
Mar 02, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Frymaster Dean H17-SC Deep Fryer Logo
153 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
