Question about Mercury Electronics KT266A Motherboard
I cannot install an agp graphics card
I plugged in the agp cga card. the display is comming but windows is not starting. it is starting on other computers why??
    President:
  • 2,961 Answers
You will have to dissable onboard graphics in the bios, or remove any other AGP card graphic card drivers that have been installed first.
Posted on Sep 19, 2007
  • andrew pester
    andrew pester Sep 24, 2007
    did the solution solve your problem?, please rate
SOURCE:
Want to install pny technologies gforce 8400gs ddr2 512mb pci graphics card but do not know how to deactivate my graphics card on my motherboard as I do not have a emachines 5250 manual can you help
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to hope this helps http://download.cnet.com/%7Bvalue=http://www.download.com/asus-agp-v7100-deluxe/3000-2108_4-68331.html
ASUS AGP-V7100 Deluxe Combo v44.03:The ASUS AGP-V7100 Series graphics cards were created to provide mainstream PC users with the radical 3D/2D graphics and video performance of the GeForce2 MX, the 2nd generation GPU from NVIDIA. With the AGP-7100 Series and its support for the TwinView architecture, ASUS has made available the most variety of models to support several dual display output combinations using RGB monitor, TV, or digital flat panel
hope this helps
May 28, 2011 | PNY Technologies VCG84512SPEB GeForce...
Self having the following configuration on Home desktop PC. INTEL 1.7GHz, P4, D845GBV motheboard with AGP ATI Radeon 9000 graphics card, RAM is 2 x DIMM DDR2 266 Hz, 1 x 1GB + 1 x 512MB total 1.5GB RAM....
Power down and disconnect AC power from your PC. Remove the AGP card and DIMM again and use some "canned air" or dusting spray to get any dust off the contacts on your motherboard and your memory and AGP card. Wiping the AGP card contacts with some isopropyl alcohol (also known as IPA or "rubbing alcohol") and a clean, lint-free cloth can also help. When everything is dry, put your card and memory back in and try powering up again.
Mar 21, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
For
I have not been able to add any AGP card to my PC.
My PC is a cube PC so I have been trying to install a "low end" AGP video card without a separate power connector. My only really requires are DirectX 9.x support and a minimum of 128MB (and no power connector)
The card I am currently trying to install is a Gigabyte ATI Radeon 9600Pro with 256MB.
I have also tried a ATI Radeon 9550 with 256MB and a Nvidia card
I have done all of the usual things, such as disabling onboard graphics, removing old video drivers, verified latest chipset drivers are installed, I reviewed the graphic adapter and don't see any conflicts etc.
I wonder if any of the cards I am trying to install will work with my AGP slot.
The manual for this Gigabyte card states "AGP 3.0 Slot or greater is required"
Unfortunately, this requirement wasn't on the Gigabyte or NewEgg web sites or the back of the box. Only in the install manual.
My Motherboard manual states "AGP 1.5v Card is required".
I got great AGP information from www.playtool.com. I used some of the tools suggested there such as Sandra Lite and other tools to try to determine what version my AGP Slot is. These tools don't seem to clearly state what
My PC is a Small Form Factor PC with 220W Power Supply.
It has integrated Intel Extreme Graphics
gBox P4 Blue CF-986L
Motherboard is a CFI-968L with last bios released (1.04)
www.american-media.com
Pentium 4 3.06Ghz
1G RAM
80G HD
Chipset is Intel 845GE
Windows XP Home
This is a awesome PC and I really would like to extend the life of it my adding any AGP card that supports DirectX 9.x
Read more: Adding ATI Radeon 9600Pro - AGP Slot Issue? - Tech Support Forum http://www.techsupportforum.com/forums/f24/adding-ati-radeon-9600pro-agp-slot-issue-128485.html#ixzz1FKivifx5
Feb 28, 2011 | ATI RADEON 9600 Pro, (256 MB) AGP Graphic...
Installed gf6200 windows wouldnt start up
remove the card, go to setup utility in disply mode section use the AGP or PCI disply setiings or auto then save settings. turn of pc, install the card and then reboot, this time system will boot up, actually system boots but no display is being given.
Jan 07, 2010 | Nvidia GeForce 6200 AGP Graphic Card
When i connected the card in AGP slot after connecting windows is running in safe mode and lines are appeared on display
i have solved the problem by putting the video priority on AGP from bios . after restarting windows was in safe mode and then i installed the drivers of ASUS A9550 128D/DR/8x
Apr 18, 2009 | ASUS A9550/TD/128 Graphics adapter -...
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: http://www.nvidia.com/object/winxp_175.19_whql.html ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
Mercury Electronics KT266A Motherboard Logo
Top Mercury Electronics Computers & Internet Experts
Ekse
Alun Cox
Are you a Mercury Electronics Computer and Internet Expert? Answer questions, earn points and help others
