Question about Cobra 148 GTL 120-Channels Base CB Radio
Just bought a cobra 148 gtl dx cant get a antenna outside just wondering the best indoor antenna i could use thanx
  • gazturner May 03, 2009
    thank you very much mchaos after reading your advice i think its two fingers up to a indoor ariel haha.ive rooted about outside and ive made a bracket (eventually) so a outdoor ariel can be used i thank you again for the advice.
    Guru:
  • 773 Answers
There really is no good indoor antenna.
You need to understand how the radio works and what reflections is.
Your radio radiates RF energy from the antenna. If the antenna is not the correct length for the frequency you are transmitting on then the signal will be reflected back into the radio and burn up the final transistor which is the lifeblood of the radio. This is your SWR or standing wave ratio.
The antenna has adjustments to correct this, and it is a simple process.
Here is what will cause you trouble. When you measure SWR in a car, you do it in an open lot, and not in a closed in area, because structures such as trees and buildings can cause reflection as well. If you inside a garage, then you will get a lot of reflection.
Beings you will be inside with the antenna, you are trapping the RF in a room, and it is reflecting most of the RF. Your SWR's will be really high, and hurt the radio.
Indoor antenna's are made so that it compensates for this, but your signal will be very weak, and your receive will be garbage.
Here is something you can do to get the antenna outside.
First get a real base antenna, like an antron 99, its good for the money.
Get 2 lengths of galvanized pipe 2" by 10 foot and a 1/4 inch thick steal plate. weld the pipe to the plate so that it will stand off it. Make sure its all the way off to side. connect the 2 pipes together, put the antenna on the end of it, and stand it up. Park the wheel of a car or truck on the plate. This will stabilize the pole.
Now you have a temp antenna tower you can take down and put back up easy.
I wouldn't go higher then 20 feet.
Posted on May 03, 2009
  • Don Reiman May 03, 2009
    You are welcome. I always say, if its worth doing, its worth doing right!
Cobra 148 gtlcobra 148 gtl DX
http://www.cbtricks.com/radios/cobra/148gtl_dx/index.htm
Nice choice of radio i have the Grant LX Uniden which is roughly the older version.
This site may be of interest also if you choose the channel mod make sure you have the right PLL. http://www.radioaficion.com/HamNews/mods/mods-cb/2428-uniden-grant-xl-mods-pll-agc-power-clarifier.html
Nov 16, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
I there got a cobra 148gtl-dx and was wondering what the best smallest outdoor antenna is many thanks
There is no "best smallest" Base antenna. You can get a workman saturn B base antenna, it is small and black, but they do not work so great.
the best bang for your buck is an antron 99 base antenna. Unfortunately it is 18 feet long when put together. But if you spray paint it a dark color, and put it up in a tree you will hardly notice it.
When it comes to base radio's, smaller is not better, and you cannot get a best.
Antron 99 is the smalles antenna that will fall into a near best category.
But the saturn B will still work if you absolutely need small. you can find a bunch on ebay cheap.
Jul 31, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
WERE CAN I FIND A POWER ADAPTER AND ANTENNA FOR A 200 GTL DX NW COBRA RAIO
We can order them Power cables. We have a few antennas instock or can order what you need. with the lowest prices around.
Dec 25, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
Have a cobra 148 gtl cb/ssb. It is brand new. I hvae it hooked up and have tuned the antenna using the swr meter on the cb. I habe channel 1 and channel 40 metting at about 1.6 swr. I have what appears to...
Hi, my name is John. Welcome to FixYa. Check your antenna, you need to set it with a real SWR meter, pick one up at any near-by CB shack $10.00. Thanks for choosing Fixya...John
Jul 22, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep out of my cobra 148 gtl dx
open the cover speaker side and look inside the radio look for a small square board that the previous owner might have had installed that would be the roger beep. the white wire is the audio wire. and usualy is soldered to the audio pin if you remove this wire the beep will be disconnected. but you will most likely want to remove the whole system but it will still work if you dont which would be best. just cut the white wire.
Feb 04, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Want to disconnect the bleep altogether on my cobra 148 gtldx
If this is a stock cobra 148 gtl 40 channel am plus side band, they don't to my knowledge come with a built in r beep. Some roger beeps are instaleed through the transmit circuit on the mic, so if not in the know Don't try to fix it.Some microphones have a beep built in. I used to install beeps on these radios using the pa/cb switch to turn them on. also try the nb switch or the swr/rf switch.
My cobra 148 gtl-dx has excessive levels of white noise that effect even relatively close stations incoming signal. is there any way i can vary or reduce the ferocity of this white noise
goto you tube and type in cobra 148 gtl dx and look for video by the cobraman in the uk - or type in the cobraman - u can contact him and he is a bit of a genius on this radio - he will even make a video and show u how to fix prblem
Jul 06, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
184 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
