Question about GE Dishwashers
I have a GE dishwasher with the following model number: GSD3230F00WW. Last night, while the dishwasher was in the clean cycle, a buzzing/grinding sound came from underneath the dishwasher. I removed the access panel to try to isolate the sound. It appeared to come from a solenoid that was connected to an arm that opened and closed something. I am not sure if the solenoid is bad or if there was something that was preventing it from operating properly. I moved the arm to which it was connected, and it seemed to move just fine. Any thoughts or recommendations would be greatly appreciated. The dishwasher is about 8 years old. Thanks. You can email me directly at pittstar63@gmail.com
  • 1,543 Answers
The part you are referring to is the pump out solenoid. ( part # WD21X10071) When the dishwasher is suppose to pump out, power is applied to the solenoid and it swings a flap inside the pump assembly to divert the pumped water out the drain instead of up into the dishwasher. If there are no signs of water leakage at the solenoid arm, I'd just ignore the noise. Note: Newer models use a separate drain pump and no longer use the pump out solenoid.
Posted on Apr 19, 2009
DISHWASHER PROBLEM
this looks like a physical damaged you should call your service centre to get it serviced.
Thanks
Iqbal
Apr 07, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher noise
FIRST STEP IS TO CLEAN YOUR SUMP AND DRAIN FILTER AND PUMP CHECK FOR NPOISE AFTER CLEANING
Dec 09, 2013 | Amana Dishwashers
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
Aug 04, 2012 | Frigidaire Professional Series 24 in....
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Both Spray arms not spinning
try removing both top and bottom spray arms some just pull off some unscrew,check the holes for any blockages seeds and rice tend to get stuck in them if plates are'nt rinsed properly, place under running tap, hook out with safety pin if neccesary
May 18, 2009 | GE Dishwashers
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Running noise
you have to dismantle the motor and get out any debris inside. takes someone with skill 10-15 min and someone without skill about 45min..
Dec 24, 2008 | Dishwashers
GE dishwasher model # GSD2200Z02AD
yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
May 13, 2017 | Dishwashers
Dishwashers Logo
230 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
