Question about Health & Beauty
Vapour does not come out of Omron NEC28 nebulizer
I have NEC28 nebulizer which I have been using for the past one year. Now the vapour doesn't come out. Please help me fix it.
  • jddenson
    jddenson Feb 08, 2013
    Yeah,this helped me out LOADS!! I woul dhave had to spend alot of money just to have them clean and regrease my Nebulizer.
    Scholar:
  • 71 Answers
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Posted on Apr 21, 2009
I have a Pari proneb ultra. the motor runs.the pump moves.but no air comes out of it. I took it apart to see if anything is wrong or looks wrong and I see a dry empty chamber.I also took off the whiteish filter cover expecting to see a dirty filter that would enter the machine but there isn't one . Is the hard thing the filter itself?
Posted on Aug 21, 2009
How much acc200 tablets must I use tob nebulize in a steaming nebuliser to nebulize a child of 1 year old?
Ever since a baby I had asthma crisis, until I used vitamin supplement magnesium. My back went out more often then I did, my wife prayed over it laying hands on; my back is fine and no more trace of asthma, thank God.
Jul 06, 2015 | Health & Beauty
I need to know an example of each part of the water cycle listed below: a. Evaporation b. Precipitation c. Runoff d. Condensation e. Transpiration
Hi Stan:
Evaporation - Hot sun shining on damp ground in morning. The moisture on the ground EVAPORATES as the ground dries.
Precipitation - Rain falling onto the ground is PRECIPITATION
RUNOFF - When rain falls onto the ground, some of it is absorbed into the ground. The portion that is NOT absorbed becomes RUNOFF in that it runs off the surface that it fell on.
CONDENSATION - Air contains water vapour, and the higher the temperature, the more water vapour it is capable of containing. This is expressed as relative humidity. When warm air that contains lots of water vapour is cooled, there will be a temperature reached where it cannot contain all of the water vapour that is present, so the excess water vapour CONDENSES on cooler surfaces. This process is called condensation.
If you Google TRANSPIRATION you will get a link to Wikipedia where you can read the definition. If you have problems with my explanations, you can also use Wikipedia to get the formal definitions.
Mar 13, 2015 | Washing Machines
Lost adapter for nebulizer, can you use any AC adapter that uses the same output neeeded?
Hi...I just looked on Ebay and there are some AC and DC chargers for your nebulizer on there.
Dec 13, 2012 | Omron Healthcare Inc Omron AC Adapter for...
Omron vibrating mesh nebulizer quit working
You must be having trouble with the battery. Also please keep the nebulizer properly cleaned as instructed on the pack. Check the connection properly or replace the batteries if needed. Also check out for more information about Omron Nebulizer on the web. It would help you a lot.
Aug 06, 2012 | Omron Health & Beauty
My ne u22v is not making mist
You should check if the battery is working fine. I don;t think Omron U2 nebulizer can have any other problem as it works really good for me. Also it is important to clean the Nebulizer properly and please check out the manual for more info. which you would have received while purchasing the Nebulizer.
Aug 06, 2012 | Omron Ne U22V Microair Vibrating Mesh...
Vapor does not come out from nebuliser omron nec 25
check the medicine chamber that has to tighten properly ,or there will be blockage in the medicine chamber ,or replace the medicine chamber
Apr 12, 2011 | Omron NEC-25 Portable Compressor Nebulizer
The baffle part of our Omron Nebulizer is broken could you please tell if we can get the same from somewhere in market or if the complete Nebulizer kit is available??
You can use pretty much any nebulizer kit (try the brand salter, item#8900), this is a universal kit and fits most nebs, I have not seen Omron offer the baffle piece seperate of a new kit (or new neb). Your local pharmacy (Walgreens in my area) sells the kits, or check with the provider that gave you the unit.
Jan 24, 2011 | Omron Health & Beauty
Hi I'm using the devilbiss 5 lts Oxygen concentrator from past 4.5 years. Recently from past 2 months it is giving some problem, during night while using machine within 2 hrs it is showing low oxygen (with...
please check if the model of Concentrator is 515HKS or aks if u have any idea to open the screw it can be very easily opened ,check if the fan which will be under compressor is running ,or any leakage from the tube point which starts from the copressor or there will be muffler connection to the compressor which will be ball shaped,
if u have any doubt after checking with this please mail me to delltazameer@gmail.com
Jan 03, 2011 | DeVilbiss 5 Liter Oxygen Concentrator with...
Health & Beauty Logo
1,974 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
