Question about Refrigerators
I have a LG refregerator.Two doors GR 726 RW Model 32RE1202 Serial 302KR00062 Water dripping from the freezer chamber to the chamber below. What could be the problem? The setting in the freezer is at High. The setting in the lower chamber is also at High. Looking forward to reply
  • francis_fred Apr 19, 2009
    Your solution seems to be a possible cause for the complaint. We will check the gasket seals and watch for a week.
    Thanks a lot for the quick solution
    Scholar:
  • 126 Answers
The water is from defrosting coil in rear of freezer and there is a drain pan under coil to make water drain to pan under unit where it evaporates from compressor heat.possible cause for water not going where it is supposed to is drain is clogged with foreign matter or frozen shut.I would suggest checking door gasket seals if you are getting this often moisture is getting in and causing lots of frost for unit to deal with and could lead to a repetitive problem.
Posted on Apr 19, 2009
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Why is water dripping from inside the fridge around the rear light section?
In some Refrigerators there is tray below the freezer section and there is a small hole in the tray. Water dripping from the tray enters a hole below in the back and goes out to a chamber.
If the hole is covered with dirt or if you place something in the line between these holes, water will drip and collect in the bottom of the refrigerator.
Sep 12, 2011 | Microwave Ovens
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
Drippy LG Fridge
should be tray under freezer
Aug 17, 2009 | Refrigerators
Drips water out of Ice maker spout
There is a valve that controls the flow of water at your door. Take the front console off and take it out. There will be wires attached to the console for your water/ice control so make sure you either tag or write down where these wires go. Then replace the valve you will clearly see that opens the water up. Take down your model and serial number down and go to your local appliance dealer so they can cross reference the part number OK? Randy B. A.I.R. Appliances
Feb 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
