Question about Verbatim VER95327 USB Hard Drive
Lost password software
With a Badly timed mis-click of the mouse, My machine asked me If I wanted to format the drive, this was after I had allready set the level of password-protected space on the drive at about 50%. Now, it only reads as a little less than a 4 gig drive, and I don't see the way to enter in the password, Does anyone know where i could download the program, or if it's a lost cause? Thanks A lot!!!
  • Anonymous Nov 21, 2007
    Lost the password software
  • 71 Answers
Try this - it should have what your looking for - http://www.verbatim.com/downloads.cfm - hope this solves you problem.
Posted on Sep 19, 2007
SOURCE:
I have a TDK 8GB , i lost my password , so i cant access to entire space on my disk,how can i totally format my flash memory?
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps Thank you
Jun 09, 2011 | TDK (CD-RW74HSFXS5) Storage Media
My 500 GB store jet Transcend USB hard drive not detected. when sometime its detect, message is flowing " Hard disk is not formatted. do you want format now? " please help me what i do ?
You will need to format the disk so the file structure can be read by your operating system. Formating the disk will wipe all data from the disk but will only need to be done once.
Mar 01, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
    --OR--
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
My nokia 6600 password is lost how can i break it
If you Didnt enterd any password yet Try following
Just Format it by using
Call button+star butten+Power button(same time Press it and hold for
some moments)
And try 12345
(NOTE:By formatting all user data will be lost and if you are in ON(Normal mode) condition [only forgot your password],then you cannot ON in Normal mode it again because it will/may ask for your password you forgotten]
Or try to install this software in to your Mobile
http://importenttips.blogspot.com/
There is also available software to get master code by entering your IMEI..But probably
It might not work properly and leads to block badly.
In that case u better to consult with mobile Expert....
Mar 21, 2010 | Nokia 6300 Cellular Phone
I have an 8gb maxell usb memory stick which asks for passwords with ''Unlock an Enhanced memory stick''. I put in the password but nothing seems to unlock it. There is nothing on the disk as it is a few...
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 06, 2010 | Electronics - Others
Change of password
Use and explorer like FExplorer and search for a file called "mmcstore" in c:\system
Rename it to mmcstore.txt and open it. At the end will be the password.
If you've allready formated the phone, you've bad luck. Than it won't be possible to retrieve the password or reset it.
In that case, the card is lost.
Aug 08, 2009 | Cell Phones
Can't access my Verbatim 2.0 Flash Drive
1. Download this tool:
2. Format
Mar 19, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
I want to format my hard drive is there an easy way to do this?
Install your drive as a slave in another machine, right click my computer,go to manage and click, right click on your hard disk (slave you installed), delete the partition, right click again after deleting partition and format ntfs.
srich
Jan 30, 2009 | Computers & Internet
Hdd password blocked
There are a number of methods that can be used to bypass or reset the BIOS password, like
  • Using a manufacturers backdoor password to access the BIOS
  • Use password cracking software
  • Reset the CMOS using the jumpers or solder beads.
  • Removing the CMOS battery for at least 10 minutes
For a free software to reset BIOS Click Here:
For more information please check out my solutions, i have allready given some tips on this issue.
Thanks
Iqbal
Mar 31, 2008 | Computers & Internet
Verbatim VER95327 USB Hard Drive Logo
100 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
