Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
The door is locked but the control lock is not on
My daughter ran a load of laundry & when she went in to put it in the dryer, the door was locked. We tried to restart...no luck. We tried to control lock & unlock...no luck. My 15 year old needs her jeans!!! No other pair in the house will work for her tomorrow. HELP!!!
  • Washblues Nov 25, 2007
    Door on my kenmore 4Ht front load washer dwon't lock?
  • showtime1 Dec 05, 2007
    my whirlpool washer says control lock and it wont turn on. whats up with that?
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
Apr 05, 2013 | Washing Machines
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
We have a kenmore he2 plus. I put in a load Of laundry and when I came back to put laundry in dryer, washer has no power and the door is locked. How can I get the door open and fix the washer
Maybe the filter is clogged and not draining the water. Have you tried cleaning the filter?
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
How to video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2011 | Kenmore Washing Machines
Door of my Whirlpool awz410 1000 does not lock after putting in laundry for it to start washing?anyone knows?it used to lock after closing but now just doesnt lock and my laundry is pilling
I took out the filter in my whirlpool AWZ410 and cannot get it back in now. It just does not lock home. If I use the machine it floods out through the filter.Any suggestions please?
Apr 23, 2010 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer door is locked/won't open
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Nov 08, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
93 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
