Question about Car Audio & Video
I need to install a radio in the dash
I need the wiring diagram for the in dash factory stereo
    Sniper:
  • 61 Answers
Http://www.caraudiohelp.com/car_alarm_install_guides/car_alarm_install_guides.htm
this should help you
Posted on May 15, 2009
How do I bypass the factory stereo amplifier?
Remove radio from dash. Unplug wires to factory amp. Install wires to your new amp. Reinstall radio.
May 21, 2014 | 2002 Chevrolet TrailBlazer
Tip
How to install Radio in Honda Accord
Things You'll Need:
* Stereo
* Wiring harness
* Dash kit
* Phillips screwdriver
* Heat shrink
* Lighter
* Wire strippers
* Wire caps
In order to install A Radio first follow steps of Removing the Factory Radio
#1
Open the center console, and you'll see two phillips screws at the bottom. Unscrew both of them.
#2
Remove the drink tray, and unscrew three more phillips screws. The center console is now loose enough to move.
#3
Pull the center console back a few inches to expose two more screws under the plastic part of the gear shift. Remove these screws.
#4
Pull the ashtray out of the dash, and you'll see one more phillips screw. Remove this screw and pull off the plastic panel around the factory stereo.
#5
Locate the metal tray under the factory pocket (below the stereo), and pull it out of the dash. There will be two phillips screws holding it in place; remove those, and then pull the stereo out of the dash. You'll need to unplug the wiring harness that is plugged into the back of the radio.
Now Install The New Stereo
#1
Assemble the dash kit, as shown in the instructions. Put it into the dash where you just took the stereo out. There will be a rectangular opening, and a pocket underneath. The opening is where the radio will go.
#2
Secure the dash kit by screwing in the one screw in the ash tray, and the two in the opening of the panel.
#3
Insert the metal cage that came with the stereo into the opening above the pocket. Ensure that the fit is flush with the pocket. Using a screwdriver, bend the metal tabs upward, which holds the metal cage in place.
#4
Start wiring the stereo harness to the wiring harness. Match wires color by color until all of the wires are paired. For example, if you find a purple wire coming out of the aftermarket wiring harness, plug it into a purple wire from the factory harness. You aren't touching any of the wires in your dash on this step, you are simply wiring the new stereo to the wiring harness.
To connect these wires you'll want to place a piece of heat shrink over one of the wires, strip the ends, twist both ends together, and then pull the heat shrink over the exposed metal parts of the two wires. Heat the heat shrink with a lighter until it shrinks and forms a tight bond between the two wires. When done correctly, you won't be able to pull the wires apart.
#5
Plug the aftermarket harness into the factory plug, and insert the radio back into the dash. If you find wires that don't have a match, be sure to cap them so that the ends aren't exposed. Exposed wires are what cause shorts and electrical problems.
#6
Work in reverse order to put the dash back together. The radio won't be secure in the dash until the dash is put back together.
Hope this helps
Thanks
on Oct 07, 2010 | Honda Accord Cars & Trucks
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
Im trying to install one of radios into my 1996 honda accord but how?
#1
#2
#3
#4
#5
#1
#2
#3
#4
#5
#6
Hope this helps
Thanks
Oct 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Wiring schematics for stereo 1995 pontiac trans sport. mising factory stereo plug. installing after market stereo what wire what color and thier functions pleas.
here you go...let me know if you have more questions.
1995 Pontiac Transport Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Radio Dimmer Wire: Brown
Car Radio Antenna Trigger Wire: N/A
Car Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4? x 6?
Front Speakers Location: Dash
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Tail Gate
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Sep 13, 2010 | Car Audio & Video
Radio installation without factory wiring harness in 1983 jeep CJ 7. Radio will be installed in secure center center console. I checked under the dash and could not locate a factory harness and not sure...
ok its easy, first see the stereo installation diagram, but i think its have spare wire harness, try to find it. inlay your wire in secured area, dont forget to install fuse in acc and in hot at all time(constant 12V)
Jun 18, 2010 | 1983 Jeep CJ7
Need radio wiring diagram for 2000 pontiac grand prix factory diagram
2000 Pontiac Grand Prix Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Sep 17, 2009 | 2000 Pontiac Grand Prix
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
