When I turn on my computer, it keeps beeping continuesly. It does boot up fine with no other problems, except for this repeated BEEP over and over. Could it be the Power supply? Its an AMD processor..thats about all I know.
  • mrninja
    mrninja May 11, 2010
    need to know the sequence of beeps (re;long or short) and make and model of your pc
    Problem Solver:
  • 9 Answers
Memory. Take out all sticks leve one, see if works
Posted on Apr 19, 2009
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
When i turn my computer on it has a long beep sound and then another long beep and wont quit... please help
Check your MEMORY MODULES . Try removing them, cleaning them with rubbing alcohol and the reinstalling them. Re-boot. That should work, ok?
Oct 18, 2010 | Acer Computers & Internet
At start the computer - 2x beep - what is that ?
Here is a good link I found on the web. You can click on link below.
Also I found Beep Code with descriptions. If you find this helpful, please rate me.
http://en.wikipedia.org/wiki/Power-on_self-test
I think a few OEM's have developed their own or use Phoenix or AMI beep codes, but for the most part motherboard manufacturers uses the IBM based ones because they are grandfathered in. Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps----------------------------CPU OVERHEATING
On the forum link below says Ram. Read on.
http://www.help2go.com/forum/computer-help/101730-post-cmos-error.html
The meaning of beeps at boot depends on the BIOS that is installed. This will give you an idea, but my guess is you have a RAM problem. Try checking that it's properly seated, otherwise you could run a program like Memtest to confirm the problem. Pls rate me. Thanks and Good Luck.
Jan 17, 2010 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Problem for HP HP Pavilion dv2000 15.4" Notebook Laptop PC The power is OK but I get 1 long beep and 2 short beeps when switching on, the screen remains blank and no activity on the laptop
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | HP Pavilion dv6000z Notebook
WHAT DOES 3 BEEPS MEAN WHEN I BOOT UP MY K7T266 VER1 0 MOTHERBOAR
*Turn off your PC
*Remove your RAM
*Clean it with cotton cloth
*Attach the RAM
*Turn on you PC.......
Repeat steps untill it will run normally.....
Jan 27, 2009 | Computers & Internet
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Oct 18, 2008 | ASUS Computers & Internet
Computers & Internet Logo
David Payne
David Payne
