Question about Bazooka ELA500.1 Car Audio Amplifier
Bazooka auto amp
How do you hook up remote? What jack does it take? Is there an internal fuse?
    Problem Solver:
  • 15 Answers
Remote wire is the blue wire maybe has white stripe that runs into stereo run from there to remote on amp as far as bass knob remote its common 1/4 stereo jack or a phono plug (looks like a phone jack)
Posted on May 22, 2009
How to i find out whats wrong with my bazooka tube i tried to hook it up to a car battery and car stereo out side but wont work ???
follow this steps and fix it. GOd bless you
  • Verify that the amplifier is turning on by looking to see that it is lit up.
  • 2
    Use a voltmeter to verify your power supply is a good 12 volts by touching the ground lead to you amplifier's ground screw and the positive one to the amplifier's constant power supply screw. Also verify that you have 12 volts coming from the remote lead wire which is usually a thin blue wire between the ground and constant 12 volt supply.
  • 3
    Look for the "thermal overload" light. It is usually a red LED on the side of the amp. If the amp feels really warm and this light is lit, the amp has probably overheated from being tuned wrong or turned up too loud and shut itself down to cool off.
  • 4
    Check the fuses on the amplifier. These can blow with extended use or during heavy bursts of use.
  • 5
    Make sure the "Gain" and other volume controls are turned up.
  • 6
    Confirm that the signal wire is still attached to the amplifier and has not come disconnected by vibrations in the car. Also check that the wires running out of the amp to the speakers are still attached to the amp.
Oct 27, 2013 | Car Audio & Video
I have an MTX1000xd and two Bazooka RS104DV's what wiring config?
Parallel will give you higher output but if you're hooking up all 3 you better use some very thick wire.Are you hooking these up to amp(s)?Sounds like a fuse is going to blow eventually too.
Good luck bro'!
Jul 17, 2010 | Bazooka RS104 Car Subwoofer
My protection mode red light comes on right when i put the fuse in my power line, even when my cars off!!! is it that my ground is bad? ineed some help!! oh ya, lol, its a ela300.1 bazooka amp!
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
Aug 26, 2009 | Bazooka ELA300.1 Car Audio Amplifier
How do I hook up speakers and an amp
Big red cable goes from + on amp to battery. Then the black - wire goes from amp to body ground (unpainted ground) The Blue remote wire goes from amp remote to the remote wire on back of the cd deck.
Then, the rca jacks go from Rear Audio Out Jacks on CD deck to the Audio IN Jacks on amp.
Speakers have Red + and Black - which match up to screws on amp.
P.S. Make sure fuse is out while hooking everything up.
Jul 09, 2009 | 1999 Jeep Cherokee
No idea!!
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Sep 28, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
Jun 15, 2008 | Bazooka Car Audio & Video
Red Led Light on My Bazooka Ela300.1
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Cheers
Dec 18, 2007 | Bazooka ELA300.1 Car Audio Amplifier
What up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
Bazooka ELA500.1 Car Audio Amplifier Logo
126 people viewed this question
Top Bazooka Car Audio & Video Experts
Radames Pagan
Radames Pagan
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
