HAVE CARRIER MODEL 58DR150-BA FURNACE SERIES 130 GIVEN TO ME. IS IT WORTH USING.ANY INFO ON THIS MODEL
  • 230 Answers
SOURCE: model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Posted on Jun 27, 2008
  • 230 Answers
SOURCE: model number for furnace
Great! That is it. Now you have the model numbers for all of your hac equipment.LOL. Anyway I do have this manual and I an send it to you via email if you like. It shows the jumper that I told you about as well as a picture of the circuit board and instructions on how to change the blower delay. Just shoot me an email. Good Luck!
Don,
cservice@square1hvac.com
Posted on Jul 03, 2008
  • 230 Answers
SOURCE: furnace model number
I believe I have the manual for this unit. Just shoot me an email and I will send it to you. It describes in detail how to do this blower off delay.
Don,
  • 124 Answers
SOURCE: Carrier Heating furnace
either the gas at the outside valve is off, or the gas valve at the furnace may be off, or the switch on top of the gas valve in the furace may be off. if they are all on, then you may not be getting a call for heat from the stat to the furnace control board. check to see if you are getting a 24 volt signal from the stat to the w terminal and common terminal on the furnace board. if you are then check to see if the voltage is arriving as 24 volts to the wires at the gas valve itself . if it is then the gas valve is possibly bad. if it is not then the board is possibly bad.look for loose or broken connections on the low voltage wiring. most unusual that the board does everything else but send power to the gas valve. you need to zero in on the valve i think and start by turning off power and that should restart the sequence of operation and you can observe it step by step . if you are not getting a call for heat then the stat may be bad be sure you are in heat , fan in auto and temp pushed up to max. if no 24 volts is sent to furnace board white and common low voltage board then stat is bad. remove it if you think its faulty and jumper the white and red wires together on the subbase. that duplicates what the stat normally does. if the furnace lights its the stat. having said that i realize the stat has to be sending a heat signal or the other stuff would'nt start. so..... back to the furnace board. check that 24 volts in from stat and 24 out to valve and that will put you on your problem item. good luck
Posted on Oct 30, 2008
tborn6
  • 700 Answers
SOURCE: Carrier Furnace is not blowing Heat
heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/58st-13si.pdf
Posted on Jan 11, 2009
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Oct 30, 2008 | Carrier 38BRC048 Air Conditioner
Model number for furnace
Don,
Jul 03, 2008 | Carrier 38CKC042 Air Conditioner
Furnace model number
Don,
Jul 02, 2008 | Carrier 38CKC042 Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
3 Tons
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
