Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
When i turn on my pc, the fan is working but no image or beep
I don't know what to do, it just suddenly not working
    Problem Solver:
  • 19 Answers
Hay im here to help you um does it still turn on at all does the monitor come on nothing if you can take the heat sink off if it is hot let it cool down first then take the klips that are holding it down you will see a metal square an there should be a little lever down beside that dont brake it if you do you will have too get a hole new motherboard so move that lever up towards you and then go as far back as it can go the take the cpu out and see if any of the pins are bent if the pins are bent then there is a way around it if you have a small screw driver bend them back if you cant then call you motherboard manufacturer or if it isnt then put it back in and do the same but reverse if it does not turn on call for help again from us i am glad to help you thanx
Posted on Apr 19, 2009
  • daleytimothy Apr 19, 2009
    did it make a bang or any sound before it turned off
All sound geting a long beep
Hearing a 'beep' is usually to warn you there is a fault. I do not know a single long beep as a code for your Notebook. Turn it on and do not touch anything, and see if there are any short beeps and/or other long beeps, and let us know
Quite often it is a fan problem, can you hear your fan running and does it sound normal?
Feb 10, 2014 | IBM ThinkPad A31 Notebook
My lenovo easycapture has changed my image to the opposite way round how do i change it back
WEBcam image problem Most WEBcams have a setting to mirror or turn the image upside down etc. Go to your WEBcam setting to set your image back to normal.
Apr 26, 2013 | Lenovo G550-29583AU Notebook
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
When i power on my thinkpad t42 the blower fan is working but ther is no display in the screen and ther is one long beep and two short beep. i don't know what happen to my laptop. please help me!...
IBMThinkpad BIOS Beep Codes: Beeps/Error Description Continuous beeping System board failure
Try reseating the RAM module/s and if you still get this bep code then the RAM may be faulty.
Remove the RAM module/s and take it to a computer repair shop and ask them to test the RAM for you.
Jun 23, 2011 | IBM ThinkPad T42 Notebook
My SerifDrawPlus X3 reboots unexpectedly after I apply image effects to an image...reads "program closing windows 7 is trying to find solution to this problem" - can you help?
This could mean your PC overheated, had a error or another problem causing Windows to force it to shut down. Is the fan in your PC working right? If it isn't working (correctly), buy a new one. If you don't know how, here's a good guide how to. If it is working correctly, a error might caused it. If so, Windows 7 will find a solution for it. Check the white flag next to the internet and volume icons. If these to are not the case, your PC might doesn't have enough memory to hold image effects and too less RAM (Memory) could cause a unexpected shutdown. Don't hesitate to ask me more! Thanks for using FixYa, and have a great day.
Jun 04, 2011 | Computers & Internet
It goes off
You probably have a faulty fan and or blocked vents with dust.
Check the fan and make sure it spins freely and turns on. If the fan is faulty, replace it.
Clean the vents and fan odf dust.
Apr 14, 2009 | Acer Aspire 5315 Notebook
6 beeps at start up
Sounds like a processor or cpu failure.
Beep Codes
Please vote if you found this information useful.
Thank You
Apr 18, 2008 | Dell Dimension 4300 PC Desktop
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
85 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
