Question about Dell Studio 1537 Laptop
DVD Disc inserted but not read
Dvd disc is iserted bot it is not read
  • aliokas May 11, 2010
    Go to:
    Start->Run (skip if Vista)->type COMPMGMT.MSC click Ok->when opens
    computer management window, click Device Manager->and look if there
    is explanation mark on DVD/CDROM Drives->if yes then double click it
    and in new window you will see Device Status.
    Post here what you see and if under Device Status you see error code then post it here to.
  • 326 Answers
Microsoft has a documented fix relating to this issue.
Try this link:
http://support.microsoft.com/kb/314060
Let us know
Posted on Apr 19, 2009
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
After I insert a dvd disc in the dvd drive, it still asks me to isert a disc in the drive. It seems that it is not able to read the disc. We currently subscribe to netflix. Certain dvd"s whhen inserted...
If it is a hardware fault, a fault in your drive, it occurs on every disk
if it is a disk fault it occurs only when faulty disks are used.
Probably Netflix discs are bad, wrong region code, or scratched, or badly copied
Jul 18, 2008 | Televison & Video
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Dell Studio 1537 Laptop Logo
112 people viewed this question
Alun Cox
