Question about Sharp AF-S120FX Air Conditioner
Air conditioner leaking
I have a Sharp AF-S120FX air conditioner. I've had it about a year. Just recently, it started leaking water on the inside of the house. It is tilted the right way, so water should drain to the outside, but still, it drips on the inside. I've read solutions where it says the drains are clogged and to clear them--but where are they? How do I find the drain pipe? I have removed the front grill and taken off the filter and just see a silver grill. Where do I go to find the drain pipes so that I may unclog them? Thank you.
  • 75 Answers
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Posted on Sep 19, 2007
  • johnlazcano Jul 11, 2011
    I just fixed this on my Sharp AF-S125RX, but I can not find my instructions on Fixya for some reason. UNPLUG THE POWER CORD and pull the unit from the window. Try not do damage the front or rear radiator coils. You basically have to remove the entire front plastic cover (both the filter cover, filter and the rest of the plastic cover too, 7-9 screws/two plastic clip-ins at the top, jiggle and it should pop out, try not to break the plastic, patience) as well as the metal casing that covers the side and top of the unit. You may also have to remove the sliding accordion flaps. All in all it is like 10- 15 screws (put them in a cup or jar don’t lose them) including the ones for the digital control (when you pop the front plastic cover off feed the control through the hole it sits on so you can fully remove the plastic cover). Don't force the plastic and be careful not to damage or soak the digital control or wiring anywhere on the AC unit. Once you get both the front, top/back covers off flush the front coil (aluminum radiator in the front) and the entire rear area of the unit too with hot tap water not too much pressure, but enough to do the job. Watch all the dirt and scum flush away. With a flashlight, peer into the guts of the unit. You should see a V shaped groove that appears from under the front coil case (my case was made of Styrofoam). Use your logic and ask: where is the water supposed to go after accumulating under the front coil’s pan (my pan was made of Styrofoam)? And clean out the obvious path. Make sure that the unit is really, really clean. Algae, leaves and dirt have to go. After cleaning have the unit flat and at a slight tilt back (same as when it is installed) and flush water into the front coils and try to watch the water come out the drain hole. The hole should drip water if the system is clean. Make sure the V groove and the entire path the water takes is well flushed out because you do not want to do this again. Nice hot, hot tap water should do the trick. Use a hose or a pot from your kitchen and pour the water, carefully near electronics (if you get wires and electronics wet give them time to dry before plugging the unit back in). Put everything back together and good luck. If you flush it right the AC unit should drain like the day you bought it. By the way many people are talking about using bleach, but I found that this can cause corrosion and it is a bit toxic especially if your system is backed up and you pour it into the water that will not drain. It may work, but I would not do it.
How much Sharp AF-S120FX Air Conditioner?
The model number you listed has been discontinued by Sharp. So, getting an accurate retail price is difficult. I did see one online marked Clearance for $269.00. But be careful buying discontinued models, as the warranty may only for a short period of time. Also, customer ratings/opinions on this model, dating back to 2005, were not good.
Hope this helps you and thanks for choosing FixYa.
Aug 24, 2011 | Sharp AF-S120FX Air Conditioner
My air is driping water inside
That's condensation; it's the humidity begin removed from your room. It's totally normal and you actually want it. Just make sure to tip the AC a little downward on the outside so that it can drip outside.
Aug 08, 2011 | Sharp AF-S120FX Comfort Touch Air...
I have a sharp cv-10 MH and it is leaking at the bottom towards the front any ideas on how i could fix this or what it could be?
Window units do produce water in operation but it normally drips to the outside on the ground. If your unit is tilted too much toward the front making it un level the water can drip to the inside. Change the tilt to the outside.
Apr 22, 2011 | Sharp AF-S120FX Air Conditioner
My AF-S120FX sharp air conditioner will work for about 15 minutes and then stop and the error/problem code E1 shows up. Do you know what this code means and/or how to correct the problem?
Check the outside fan and condenser . condenser must be really clean and fan must operate. Make sure the fan on the evaporator in the house is working as well. Pressures exceed rated running values if not.
Aug 04, 2010 | Sharp AF-S120FX Air Conditioner
How do you replace the cooling agent? Is it Freon based?
Must be done by licensed technician. Gas must be reclaimed and requires special equipment to recharge. But it is a normal procedure, however, it should be checked for leaks if it is losing its charge.
Jun 10, 2010 | Sharp AF-S120FX Air Conditioner
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
Apr 07, 2010 | Sharp AF-S120FX Air Conditioner
My air conditioning does not blow out cold air. Is there something I should do to it? Add water??
Have the gas checked, A/Cs work with refrigerating gas. This should be done by and A/C technician.
Jun 29, 2009 | Sharp AF-S120FX Comfort Touch Air...
Room Air condotioner Sharp AF-S120FX-A noise from middle of fan
You can get a zoom spout oiler at your hardware store. Slide the ac out of its housing until you can see the fan motor clearly. Use a flashlight to see the shaft. Put oil right where the shaft goes into the motor, both places if you can see them. While there, check the ac for sludge or anything else you can **** up with a shop vac.
Apr 29, 2009 | Sharp AF-S120FX Air Conditioner
My Sharp Room Air conditioner (Mod.AF-S120FX-A) when it's starts
Most likely the terrible noise you hear is the compressor starting... Sometimes it is louder than when its runs continuous. Just make sure if the unit is shut off allow a few minutes for the freon to equalize before restarting the unit. Its possible that the Compressor is going out, But as long as it cools and the noise goes away after a minute or so, i wouldn't worry about it to much.
Sharp AF-S120FX Air Conditioner Logo
489 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
