Question about Acer Aspire 4930-6862 Laptop
DVD Disc inserted but not read
When I insert the DVD disc; it is not read by the vista home system
  • aliokas May 11, 2010
    Go to:
    Start->type COMPMGMT.MSC click Enter->when opens
    computer management window, click Device Manager->and look if there
    is explanation mark on DVD/CDROM Drives->if yes then double click it
    and in new window you will see Device Status.
    Post here what you see and if under Device Status you see error code then post it here to.
EVERY NOW AND THEN THE DVD PLAYER WILL READ NO DISC INSERTED WHEN INFACT THERE IS A DISC INSERTED
Your lense is becoming dusty.Carefully take off cabinet and clean with a Q-tip
Mar 27, 2011 | Sony Audio Players & Recorders
I have a philips hts6510 home theatre system and when i put a dvd in to play it says no disc
hi,
Normally a dvd player shows the message NO DISC when,
1. The disc inserted is bad.
2 The lase pickup unit inside the dvd lost its reading intensity, dirty lens or the spindle motor damaged .
In your case the second one happened. the intensity of the laser pickup unit has lost or the spindle motor faulty or there is some dust on its lens. just insert a cleaning cd in it for two or three times. then check again is the DVD is reading or not
if the problem remains then you have to check the motor and the laser pickup unit. the lase pickup unit have two laser emitter and receiver in its inside . one for reading and playing DVDs and the other for CD and MP3. also the spindle motor runs in different speed when u insert dvd and cd.
Open the cover of your dvd player and power it on insert an audio cd and watch is it reading or not also notice the speed of the spindling of the cd. if the audio cd reads and play. then the possible problem is the spindle motor
To conform it remove the audio cd and insert a dvd. watch the rotation of the dvd. if it feel very hard to rotate it then, the spindle motor is damaged. if so replace the spindle motor if it runs more the the speed of than audio cd then the laser pickup unit is faulty. Then u have to replace the laser pickup unit.
if you need any further assistance from me , feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips HTS-6500/37 System
Dvd not playing
2008 EXCHANGE MODELSNO PARTS FOR SERVICE
Aug 20, 2009 | Polaroid PDX-0073S Portable DVD Player
CD/DVD reads no disc after inserting working CD/DVD
More than likely it has dust on the laser eye, it will need to be cleaned
Feb 22, 2009 | Bose Lifestyle 48 System
DVD home theater system
Disc is either to scratched or may have a hairline crack on disc. If this happens to all of your disc's, then you have a laser read problem. This can be caused by high humidity as well as dust and debri. Try blowing the unit out with canned air.
Mar 02, 2008 | Computers & Internet
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Acer Aspire 4930-6862 Laptop Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
