Question about Toshiba Satellite R10-S802TD Tablet PC
Wireless lan i seem to be connected on the wireless lan and have very strong singal but the internet wont work
Check ur gateway setting and also check that the access point or router is conneced to internet or it is down.
Posted on Mar 21, 2008
SOURCE:
Why am I unable to access the internet?
Take your tablet to a HOTSPOT with free WiFi and try to access Internet there. If can't, it's because inbuilt wireless adaptar has some problem.
May 30, 2015 | Tablets & eReaders
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Amazon kindle registration
Just a few questions.
is your computer connected to the internet with a wireless connection, or with a cable? Is the internet connection you see on the kindle, the name of your wireless router? Did you setup the wireless connection on your kindle, using your connection name (the name you gave in on the wireless router you own) and password.
If you answered one or more of these questions with a no, first solve or change that. When you don't have the answer, because you don't know, you have to asume it is a no.
please tell us you did setup the wireless connection correct, so I can look to other possibilities.
Aug 02, 2014 | Amazon Kindle Fire HD
Error 8007139f
i had the same problem and my system wont work and wen i turn on my tablet it says. tablet useless now f6bc4264-7e1c-4f20-94ab-44397ef30af8.jpg
Jun 12, 2014 | Dell Venue 8 Pro Tablet Computer
Zeepad internet
cannot get internet, signal is strong but wont let me log on,all my other stuff is working this is a new tablet i just received only two days ago it is the model zeepad 9xn cpu all winner boxchip a13 cotexa8 1.2ghz ram 512mb ddr nand flash 8g 9inch capactive touch screen 800x600,5point touch os android 4.2 paid good money but cant use
Nov 10, 2013 | ZEEPAD 7.1 4GB Android 2.3 Tablet, inbuilt...
I cant seem to get connected to they internet
check your proxy server setting, by going to internet option setting, connection, lan setting and uncheck all boxes
Jul 25, 2011 | Coby Tablets & eReaders
I cant connect to internet but i installed the necessary driver
To connect to the Internet you need a few extra things aswell as a network card.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
May 18, 2011 | IBM ThinkPad X41 Tablet PC
I just got a T301 tablet/ereader. I cannot download books for some reason. Any suggestions. I have no idea what I am doing incorrectly. Thank you
LETS CHECK YOUR INTERNET CONNECTION FIRST
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 24, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
Cannot connect the bluetooth. when I attempted to connect using the Wireless LAN, it complained that it is looking for a certificate and about 5 minutes later, the screen turns blue with and error message...
Enable both wireless units (Bluetooth & Wireless LAN) in BIOS settings. If bluetooth doesn't work for an Acer supplied driver refer to DriverMax online drivers. It could rectify the problem.
Oct 21, 2009 | Acer TravelMate C110 Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
184 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
