Question about Kenmore Refrigerators
Loud buzzing noise from ice maker
The ice maker is making a loud buzzing noise. I switched the lever to stop and the sound still continues. I also notices there is frozen water underneath the ice maker into where the frozen food is.
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Posted on Aug 30, 2008
  • 114 Answers
SOURCE: Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
Posted on Sep 28, 2007
elbozi
  • 4 Answers
SOURCE: two issues
Well here is How I fixed My French Door Ice Maker, It made the same loud crashing sounds, and seldom put out much ice. To the point that it made no ice at all.
First, Make sure you can get water out of the front, if not, your water lines may be clogged.
The second thing you can do is hit the secret RESET button on the upper front side of the ice maker. See my first image for it's location, it is a soft rubber button.
The third thing.. In my case the reset button worked for a little bit. But eventually stopped. I had to remove the ice maker, and found that that several rows of ice had gotten stuck. The swinging arm that smacks the ice out would just strip the gears banging that ice to no avail. So opening the ice maker up and cleaning it out helped. I also cleaned the sensor contact with some alcohol. It is a thin metal strip close to where the gearing housing is. This I believe is ultimately where the problem starts. It allows the trays to get overfilled, and the ice can't be released. Once I cleaned out the tray of stuck ice, cleaned the sensor, plugged it back in, and hit the reset button once more, It was making loads of ice once again. If this fails, you can get a complete new ice maker online, I found a vendor on eBay selling it for a reasonable $80. You can use my pictures to see how to disassemble for repair ore replacement. My fridge by the way is the RF267AARS.
the part number is: DA97-05554A
It works with the following refrigerators
Samsung RF267AABP Samsung RF267AABP/XAA Samsung RF267AARS Samsung RF267AARS/XAA Samsung RF267AASH/XAA Samsung RF267AAWP/XAA
Posted on Oct 31, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
Read this, it directly applies to your machine.   After you read this, if you have questions, just ask.
Clicking Refrigerator
Thanks, Bill
Posted on Nov 08, 2008
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
I have a samsung side by side fridge and it is an RS285LA. For awhile now it has been making this buzzing sound from what sounds like to be coming from the back. This buzz sound is kinda loud cause I...
its the relay for the ice maker.. they are loud if the don't have water going threw them, you may want to shut off your ice maker. lift the arm to the up position. that turns off the ice maker.. if'n i was of hel vote YES .. jay the pool pump repair guy in longwood fl
Jul 05, 2011 | Refrigerators
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
452 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
