Question about Boating
Anchormate 18 motor will wind up, but won't go
Minn kota deckhand 18 anchormate motor will wind up, but won't go down ?
  • bbishy May 22, 2009
    I have a deckhand 35 with the same prob I put a new switch in and that didnt help although it was a generic switch not a minnkota switch kit not sure that would matter
2 Suggested Answers
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
    it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
    Sep 21, 2008 | Minn Kota Maxxum 80 Freshwater Bow Mount...
    My minn Kota deackhand 35 won't lift a 28lb anchor
    How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
    Sep 29, 2015 | Minn Kota Boating
    Minn Kota rip tide st 55 very noisy
    is the prop shaft bent you may have busted a magnet in the motor dragging now
    Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
    Anchor will not go down but will go up
    I have two deckhand anchor units. I ve tested both on battery, and both went up. I replaced switches, and I get nothing, but I heard a light click coming from unit. Is the motor bad?
    Nov 09, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    Anchor pulls up won't release to go down on either of the two switches
    Im getting power to motor, but can't get it go down. When I hit switch I can hear a clicking sound from the unit
    Nov 05, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    I have a Minn Kota Deck Hand Ser. No. MK01798492 I can not find a modle # on it. It came on the boat i bought used. it did work now it will not let the ancor down. I took the cover off, found a spring off...
    39 2372700 COIL SPRING ??
    DeckHand 40, 12 Volt, 25 to 40 Pound Capacity, 2377106 - 2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015,2016,2017
    DeckHand 40 - parts diagram
    Aug 07, 2017 | Minn Kota Boating
    I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
    Good Luck!
    Jun 09, 2009 | Boating
    Boating Logo
    295 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
