Question about Karcher K2.26 Electric Power Washer
How do i know if my outside tap has a non - return valve i want to start using a pressure washer
  • Philip Gaut May 11, 2010
    What country are you in?  I can advise on UK plumbing but not elsewhere.
  • 174 Answers
If del_brenda_s lives in Canada or US, just go to the hardwre stire and get a Gardena connection for your garden hose. Under $10
Posted on Jun 05, 2009
  • 92 Answers
Dear del_brenda_s,
I have been servicing Power Washers for the last 5 years. And I cannot understand why you need a non-return tap outside. I think "outside" you are refering to the main supply after the water meter.
Well if your power washer needs a non-return, you can fit a cheap garden hose non- return attachment.
Regarding the non-return at the outside tap,..this is most probably NON-RETURN. If you want to be sure you can contact the water works division of your country and city...and I am sure they know what sort of taps should be used. In my country it is a must that a non-return outside tap is used. This is important so that when there is a cut in the water supply, the water meter and the whole system will not have to be bled out of air when the water comes again.
Regards,
Fulltech.
Posted on May 31, 2009
My Karcher 11/5 U starts and stops when not in use
Pressure washers do this due to a valve called the 'unloader'. It's purpose is to relieve pressure from the pump when not in use so it is not under continuous strain, but there is also a pressure switch linked to the motor that will fire it up if the pressure drops to low so your washer is always primed and ready for action. This means tht the unloader relieves the pressure, then the electric pressure switch pumps it again to keep the pressure high. If it is doing it a couple of times a minute I wouldn't worry, but if it is every few seconds it would indicate to me that the pump is losing pressure constantly somewhere. Main reasons would be;
It could be a weak unloader, which is basically a strongish spring and a couple of plates and seals, but would normally come as a kit or complete valve.
A leaky seal in or around the pump. If this was the case you should see water leaking from the unit somewhere and then you could pin point the worn/damaged seal and replace it. Most washers have seal kits and it is advisable to replace seals in this way as it saves time later (especially if a worn seal, others will be wearing out too).
Failed non return valve. In the pump head there are normally two non return valves per piston (one directly after the piston and one a bit deeper into the outlet side) and also a couple in the back end of the pump head. These basically allow the pressurised water to be pushed through the pump and stop it flowing back into the cylinder set. If the water can flow back as well as forwards it will not keep pressure (like blowing a balloon up but not holding it shut between breaths). Non return valves will normally be supplied as a set and will be assembled already so just push into place when the pump head is apart. You would not see a leak if thesse valves are perished as the water will just flow back toward the source instead of out of the machine anywhere.
Sep 28, 2014 | Karcher Garden
My pressure washer starts and stops constantly. It seems to not hold pressure. Is that just a seal replacement?
It sounds like there is a leak in the output pipes or the non-return valve on the input to the pump is not sealing properly and allowing any pressure built up to leak back. If there are no leaks in the output pipes then it must be the non -return valve that is faulty. You could try removing the valve an cleaning it but usually once the valve seal is damaged, the only fix is replacement of the valve.
Nov 28, 2010 | Karcher Garden
Turn water on then actuate wand trigger. Pressure washer leaks when wand trigger is actuated and has very low pressure/flow output. After releasing trigger the pressure cycles on - off at approx 1 second...
You gave a very close solution yourself for the problem. But other leakages can cause such symtoms.Forexample a leaking head or a leaking chemical inlet. These can be caused because the spill valve (pressure control valve) is stuck. When this valve stucks it will leave a micro switch ON. So the machine keeps working with the gun closed. This will in turn creat internal pressure and damages the head, valves and chemical non-return and even damage outlet hose. So besides fixing the leakages you must check and service the spill valve. I often replace the spill valve. One must also checks if the micro switch is faulty. Now very important that what you mentioned that the machine cycles at one minute intervals, with trigger closed...this is most probably always the spill valve fault. If you open machine you see a place where there is a wire..this belongs to the micro switch...under you find the spill valve. Intake and suction valves may now also have a fault. Also there are systems with non-return valves at the machine outlet. You have to tackle by elimination. Fix the leakage..then tackle spill valve and micro switch.
Fulltech.
Jul 03, 2010 | Karcher PSI Electric Pressure Washer
The water is going out by the inlet soap fitting, and the soap compartment gets full of water
You will find that the non return valve as stuck inside your pump.If you follow the pipe back to the pump you will find a non return valve which is a ball and spring. Please remove this and replace if required.
this should then stop the water and soap returning back.
Jun 23, 2010 | Honda Pressure Washer PSI 3000
Karcher k3.86 lowered operating pressure and constant surging at idle, it back feeds into the water feed/supply hose until trigger is pressed
It sounds like your non-return valves are damaged. in the pump there are usualy 3 non-return valves, these are located under 3 large brass hexagonal caps. take the valve out and inspect them. if you are lucky they may just need cleaning, as sometimes foreign object that enter the machine with the water get jammed in the valve. if your unlucky the springs in the valve will be damaged and you will have to replace the valves. I hope this helps you out.
Sep 20, 2009 | Karcher K2.26 Electric Power Washer
I have tried to use my Karcher washer model 411A using the suction tube which is immersed into Patio cleaner bottle but it does not work what am I doing wrong
you have to lower the pressure at the lance for the detergent to be drawn into the hose. It works on a venturi principle.
on the lance you will have to twist or pull back the end for it to go into low pressure mode.
the easiest way to check it is working is to take out the lance extension , the bit that fits into the trigger on a bayonet fitting. run the machine and see if it then draws in detergent.
If it doesnt draw detergent then look to see if there is a detergent valve fitted to the filter that goes into the bottle and check that it is fully open. sometimes ther is a non return valve fitted into the filter too.
it could be that this non return valve has stuck. A poke with a bit of stiff wire should free it off its seat if it is that problem.
hope this helps a little
Jul 17, 2009 | Alfred Karcher Pressure Washer
I have a detergent tank and cant seem to get detergent to come out what do I need to do?
Dear bug4222,
I have never worked on your type of machine. But generally this is what you do. Disconect the pipe from the inlet to the machine. Attach another pipe and put the other end in a bottle of water. Start machine and on low pressure see if the machine sucks water from the bottle. If this does not happen, try to service the inlet part at the machine. This usually it will have a ball-bearing as a non-return valve. This non-return valve sometimes gets stuck. If you see that you have solved the fault in the non-return valve, attach the detergent tank as it was, but instead of detergent, use water. You should always use low pressure. If all is OK, try some detergent. Always remember that after using detergent, always pass clear water from the detergent tank. If you leave detergent in the system, this will cause problems.
Regards,
Fultech.
Jul 16, 2009 | Campbell Hausfeld Garden
Porter Cable pcv2250 pressure washer shooting water out of siphon
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Jul 06, 2009 | Porter Cable Cable Commercial Pressure...
Honda p/washer won't **** up cleaning chemicals cleaned filter,still no go.
In general, pressure washers will draw detergent from the reservoir only when the spray nozzle is set to low pressure. At high pressure a non-return valve closes to prevent water flowing back in to the reservoir. If you've got the spray nozzle set to low pressure and still have the problem, it may be that the spray nozzle is partially blocked - you can try clearing it with a length of wire.  Failing that, the non-return valve is probably stuck (and that may need professional attention).
Apr 17, 2009 | Honda Garden
Karcher K2.26 Electric Power Washer Logo
234 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
