Question about Pioneer VSX-D514 Receiver
Problems with Sharp Blu Ray Player "copy protected signal"
I just purchased a Sharp Blu Ray Player that I run through a Pioneer Elite vsx-01TXH receiver and to my 52 in. Sharp HD TV. When I try to play a blu ray (or a regular dvd) I get the following error message: "Copy protected signal can not be outputted to the connected equipment".
I have tried three different sets of HDMI cables and connected the player directly to the TV (bypassing the Pioneer receiver) and get the same error message.
Any help on this would be greatly appreciated!
Thanks,
R
  • Anonymous Mar 21, 2014
    Problems getting everything hooked up to work. AT&T says it is the remote, sending a newer model remote.
    Scholar:
  • 120 Answers
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Posted on May 20, 2009
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Copy protected signals cannot be outputted to the connected equipment is the error I get when playing any disc
you must have it connected to a recording device hence why you are receiving the error
Feb 26, 2011 | Sharp AQUOS Blu-ray Disc Player
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Apr 16, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
Can i get true hd audio through a pioneer elite vsx-36tx
I have found out that using a Blu-ray player that has built in true-hd decoders and a 5.1 or better analog out to my six channel input that my problem will be solved. I was advised that the Panasonic BD-55 was a good choice since both the analog and bitstream feeds are always active without changing settings.
Thanks for your help.
Dec 11, 2008 | Pioneer VSX-36TX
Vsx-94txh
If I'm not mistake, it's dependant on you monitor's ability to display 1080p. I believe the defaul setting on the 94TXH is to read the TV's max resolution and anything above will not feed.
Dec 22, 2007 | Pioneer VSX-94TXH
Pioneer VSX-D514 Receiver Logo
761 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
