Question about Bissell 6594 PowerForce Bagless Upright Vacuum
It will not suck up materials on the vacuum part. the hose works just fine when it remains plugged in to the upright part
The upright part of the vacuum will not pick up. i have changed filters, belts, etc.
  • 1,463 Answers
Re: it will not suck up materials on the vacuum part. ...
Hi pop into bissel web page faq page type you querry see if there an answer
Posted on Nov 11, 2007
  • 48 Answers
Bottom hose clogged in bottom part of machine
Posted on Nov 15, 2007
0 characters
3 Points
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
My vaccum is not sucking up barely anything and the cup is empty
In spite of it's advertising, it may actually be a clogged air passage. Remove the debris cup and reach into the air passage with a hooked wire to pick out any material. Do the same from the under side of the machine. The usual point of clog is where the upright and base components bend--there is a flexible hose there that tends to catch things large or sharp. Make sure the air exit filter is not plugged. Good luck!
Aug 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My bissell cleanview is blowing not sucking in the base. the hose works fine and the bruch appears to be rotating fine.
Try reversing your hoses.
Hope this helped.Let me know by rating me
For more help go to live chat.
Jan 30, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dyson DC14 won't **** from hose but works fine otherwise
There is probably a clog in the U-bend on the back of the unit at the bottom. Removed with a twist of a plastic screw by a coin or screw driver. If not in the U-bend check in the hose/wand.
Nov 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hose attatchment won't suck
Sounds like you have a clog, either in the hose or the inlet down by the brush roll to where the hose plugs into.
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell 3594 vacuum won't suck..
Hello Bisselluser!
I had the same problem, and figured out it was the belt. Mine slipped off.
Just remove the bottom plate (four screws) and there it is!
I hope this works for you. Mine is working fine now. :)
Vist me at The Catbird Seat:
Nov 07, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Won't suck, just blows
it has a blockage - you will have to find it - probably in hose leading away from roller
Mar 18, 2007 | Kenmore 32734 Upright Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
153 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
