Question about GE WSM2420T Top Load Stacked Washer / Dryer
A GE stacked Washer/Dryer unit
Washer works well. Dryer will run, but will not heat up. My thought is to clean (blow out) dryer timer and clean contacts. Check that door is making proper contact when closed.Try to track that heater element is getting power. anything that I missed????? What is most common solution????????????????
  • kellygirlnai Apr 19, 2009
    Sounds like a very common place to start, thanks. Kelly
  • kellygirlnai Apr 20, 2009
    I checked the vent and it seems clear. However, I found the schematics and checked the resistance on the two thermostats. The operating thermostat measured 7K ohms instead of the 3200 to 3900 ohms, the high limit thermostat ohmed at 0 (zero). So did the heater element. I plan on replacing these three elements. anything else to check before I go any farther????
    Sergeant:
    Champion:
  • 289 Answers
Hi..It sounds like the heating element.you cant
fix it of your own,it needs a repair man.
check it out..
thank u..
Posted on Apr 20, 2009
    Brigadier General:
  • 3,614 Answers
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.
Posted on Apr 19, 2009
  • micromaster
    micromaster Apr 19, 2009
    just let me know.
    please rate/accept my solution.
    micro
Dryer not heating
Check Heating elements if ok check the in line fuse that go to drying element and if it open replace it and clean filter and check pipe that blow out side make sure it not stop up because if in line fuse is open stop up filter and pipe that blow air out side will cause the heating element in fuse to open up. And check for lose wire going to element to.
May 30, 2014 | Kenmore 98702 Stacked Washer/Dryer
My GE Spacemaker dryer will run but the washer will not start in any cycle (stacked unit)
It looks serious problem. You should go to your nearest repairer to solve the problems if you don't want to stay without your washer.
Mar 13, 2014 | GE Spacemaker Washer and Dryer Electric...
Dryer runs but heating poorly
first make sure the vent is clean to the outside from the dryer,then it could be packed with lint inside the unit,after this is complete,then the hi-limit/cycling switch on the element case can cause early cycling and low heat output if the unit heats by electricity,ig gas it can be a cycling switch on the burner tube,radiant sensor on the burner tube,gas valve coils are weak on the gas valve
Aug 01, 2010 | GE WSM2700D Top Load Stacked Washer /...
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Dave
Jan 23, 2010 | Dryers
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
GE WSM2420T Top Load Stacked Washer / Dryer Logo
198 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
