Question about D-Link DI 514 Wireless Router (DI-514)
Have a Toshiba A30 laptop - Power On does not work?
Have a Toshiba A30 laptop - will not open. When I press power on I get 2 flashes on led and then nothing. Can you help me?
    Scholar:
  • 134 Answers
Press down the reset button on the router for 5 secs using a paper clip
Posted on May 03, 2009
Toshiba Laptop will not boot
Either the battery is dead or the power supply is damaged.
Mar 19, 2014 | Toshiba Satellite L875ds7332 Notebook...
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
How do I restore my Toshiba Satellite A30 303 back to factory settings.
press power on button and press F2 to enter BIOs
in last select restore to factory setting and save changes by click on link or press F10
Aug 20, 2011 | Toshiba Satellite A30-303...
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
Ibm thinkpad A30 doesn't receive power from new or old power cord.
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jun 30, 2010 | IBM ThinkPad A30 2652 Notebook
SP 6000/PS6000E-207PK-EN Will not fire up. If press start, then LEDs flash Orange (1st left) 5 times then 2, then 1 and then repeats. 3rd LED (green) stays on. If battery is removed, start button pressed...
You got some short on board, You need techguy. Or possible Bios flash, Remove the Harddisk and press the power button.
If nothing change, Remove power, battery, cd rom, Hdd, memory.
Then put one stick of memory, power up, see anything comes up.If does, power off, put the other memory plug in power, fire up.
If does ok. Then plug off, and put hdd without CD rom. see if it did work.
If none is worked as I say you have short or CPU fan is not functioning.
Goodluck.
JMC
Aug 17, 2009 | Toshiba Computers & Internet
Flashing Charging Light on AC Power
shortage on the motherboard, needs new motherboard.
Mar 09, 2009 | Toshiba Tecra 9100 Notebook
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
D-Link DI 514 Wireless Router (DI-514) Logo
89 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
