Question about Ultrak Event Timer Stopwatch
Battery replacement Put in a new battery, but watch will not reset. There is no LCD display?
Is the battery in upside down? Joe
Posted on Oct 03, 2007
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Is there a reset button? i put a new battery in with difficulty and it wont work. this is the casio g3011
    No! there is no reset it is possible the battery is not correctly seated, check to make sure the positive and negative match what the watch indicates, because if the battery is reversed it will not work. If you still have issues take it to a watch dealer.
    Jan 01, 2011 | Casio G3011 Duplex LCD Watch
    How do I replace the watch battery for Casio DW-6900?
    mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
    Aug 27, 2010 | Watches
    I have a Casio 1470 pathfinder watch. I did not use it for several years The batteries ran down, have replaced them and now have no display or functions
    mcdevito75 here, I would see the jeweler who installed the new batteries and ask to have the battery install double checked so they are makeing proper contact with the LCD movement. In the meantime you can try to hold down the MODE button for a few seconds and see if the display appears, also if the display screen has turned very dark, your Casio may have had it, as the LCD display could have gone bad. New batteries should bring up a display even after the watch has been stored. Hopefully the display is still a grayish color and the new batteries need re-alignment.
    Aug 11, 2010 | Casio Watches
    Poor cassio watch display
    You don't say how old the watch is and whether it has always had a display problem. I have seen several watches with weak displays, but generally they are older watches and I suspect the problem involves a corroded contact somewhere in the "movement". You might want to visit the Casio website and download a copy of the manual for your watch. It may say something about the display. If you watchis fairly new it may still be under warranty and again, contact Casio to see what you need to do.
    Jun 13, 2009 | Casio G3011 Duplex LCD Watch
    Polar F6 - Battery replaced, display corrupt after watch loads.
    I had the same problem and attempted what banjodoug suggested above. It did not help. I had a faint display even before I re-inserted it into my watch frame. I surmised it wasn't the battery position.
    I then took apart the damn thing and put it back together several times, each time rushing to push the setting/center button only to derive the same problem over and over.
    I then took it apart one more time and pinched in all of the sides of the metal frame that holds it all together, thinking that I had a bad ground. After I did that, I reassembed it and waited. The display came on with the test display and then eventually went to the standard display on its own and all was good to go.
    I suspect the issue was solved by correcting an improper ground and a proper initialization process - both solved by the steps I took above.
    Hope it works for you!
    Feb 21, 2009 | Polar F6 Wrist Watch
    Please help me to replace battery on my casio F-91W
    This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
    Aug 14, 2008 | Casio F91W-1 Wrist Watch
    Battery change and then reset
    If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
    click below for video guide;
    G-ShockBattery Change Tutorial
    hope this may help
    DON'T FORGET TO RATE
    Regards,
    VOTIT
    Jul 29, 2008 | Adidas Watches
    Battery replacement for a G-shock.
    The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
    Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Ultrak Event Timer Stopwatch Logo
    284 people viewed this question
    Top Ultrak Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you an Ultrak Watch Expert? Answer questions, earn points and help others
