Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer stops but will run if you unplug it, let it sit for a few minutes and replug. It runs for a few loads and then stops again. Your assistance is appreciated.
  • 67 Answers
You have a bad motor
Posted on May 18, 2009
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not working it begins to spin stops and has the letters LE appearing.
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Goodluck..
May 27, 2008 | LG Washing Machines
Whirlpool GSQ963ILL0 top load washer. Stopped dead in middle of agitate cycle. I fear I overloaded it. Now just sitting, full of clothes and water, and won't do anything. Any advice?
Hi jim_zervas,
Firstly, unplug the machine. Then first thing to do is remove the clothing, and bucket the water out. Then run the machine again.
Let me know what happens?
Kind Regards
JEDEMEYER1
* Please accept my solution if it solved your problem
Sep 03, 2011 | Whirlpool GSQ9631L Top Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
After washer runs for a few minutes it stops and runs agains, stops and runs again with stop and start intervals getting shorter and never finishes cycle. Seems it's unable to spin continuously.
there are usualy sensors for the spin so that the drum is balanced properly if one of the sensors is faulty it will not spin or if the wate is not draining aswell so check the owners manual to see if there are any tests for he sensors that can be run to give you a code for the fault
Nov 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine stopped running during cyccle. No error
Unplugged the unit; replugged it. Buying a new machine.
Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Dryer GEW9250PW will not start when I push the button. All lights on etc. Literally froze in between loads.
Unplug the machine for a few minutes and then replug, it will reset the controller. If this does not work, then perhaps a component has failed
Aug 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stopped during wash cycle.
UNPLUG THE WASHER AND TAKE THE 3 SCREWS THAT ARE ON THE BACK OF THE WASHER OUT AND REMOVE THE TOP PANEL OF THE WASHER. CAREFULLY UNPLUG AND REPLUG IN THE WIRING SO THAT U WONT GET THEM MIXED UP. DO ALL OF THEM, FIRMLY BUT GENTLY. THEN HOLD IN THE SIGNAL CYLCE LITE FOR 3 SECONDS. TRY TO RUN A LOAD AND SEE IF THAT WORKS. IT DID FOR US, SO FAR SO GOOD. GOOD LUCK!!
May 30, 2009 | Whirlpool Washing Machines
Whirlpool LSR5132PQ Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
