Question about Nintendo DS Lite Console
NO card inserted
Mine goes to the DS screen not the AR whats wrong, and can i fix it?
  • lolsgod Apr 22, 2009
    Can i also use a clean paint brush?
    Scholar:
  • 72 Answers
Look where the game card goes called (slot a) see if the pins are bent or crossed over themselves need good eyes and a torch if so you need to replace the slot a or see if you can clean the pins in the game card with a very stiff pig bristle brush (small school paint brush but cut the bristles to about 5 mm and use it like a scrubbing brush not across but lengthwise) then with it turned on insert the game in and out a few times slowly to see if it worked sometimes the get bad contact with the pins and the card Hope this helps
Posted on Apr 20, 2009
  • chippit
    chippit Apr 22, 2009
    or you could probably use a very hard toothbrush try anything that wont hurt the pins you want to clean them not a braze them
  • chippit
    chippit Jun 09, 2009
    To lolsgod should be able to do that too but check if an original game works first if it does then clean the pins on the ds card in question then try it push it in and out a few times slowly to try and get a better contact on the pins if all else fails try to get a lend of another card off a friend to try could be a knockoff from china i have seen some bad ones also take the mem card out and see if goes to a cant find file menu if so then your memcard could be crook good luck
    Problem Solver:
  • 13 Answers
The best method to remove any foreign objects is to tap DS slowly holding upside down. If it does not work...
Try looking into the Slot, put it an angle or use a flash light to see if the pins are bent. 95% of the time this is the case. If you observed that the pins are bent, you will have to see it very closely, then you need a slot replacement. I found there is no work around to this, if you try to insert some kind of brush to clean, it will further damage the slot and you risk blowing the fuse next time you try to check with the card inserted.
The replacement card slot itself is $5-7 on eBay but If you are not very good at soldering, I mean VERY GOOD do not attempt to replace the slot. There are lot of cheap repair services that take care of this problem on eBay or online.
Posted on Nov 17, 2009
Action replay doesnt play
try taking out the action replay and give it a good blow where the contacts are, also give the ds a good blow where the cartridge goes, thats either the problem or you may have updated the ds to the latest firmware and this does cause problems with action replace and r4 cards so that might be your problem, if you had another ds or no anyone with another ds then try the card in theirs, that way you can make sure the card works
May 18, 2012 | Nintendo DS Lite Console
When i enable cheats for animal crossings on ds lite, my screen goes to a white screen. if i disable the ar cheats i can play the game fine. i am using a r4 card with firmware 1.8 and the action replay...
i think you might eather have A. have terrible cheats B.something wrong with your ds or C. your game is screwed up sorry mine did the exact same thing
Dec 01, 2009 | Nintendo Animal Crossing for DS
Ar ds white screen of death
well before you start hold down a-b then start holding those
Jun 11, 2009 | Datel Action Replay for Nintendo DS
My AR won't read the game! Help!
heres what i did i put the action replay in select the codes i want then i take the action replay out and put the game in it may sound crasy but it works
Jun 03, 2009 | Datel Action Replay for Nintendo DS
Action replay
Have you tried inserting the game while the DS was off? I too find that the Action Replay doesn't recognize when you insert a game while the AR and DS is on. So you may just need to turn off your DS, insert the game, and then turn on your DS and activate the codes
Aug 03, 2008 | Datel Ultimate Codes: God of War II
Code insert buttons
Have you tried just using the Normal DS buttons rather than the touch screen? I don't know how bad your touch screen is calibration is for your AR (mines pretty close to fine), but if you find that the touch-screen is frustrating you too much, just use the normal DS buttons. Sure it will be a bit slower, but it won't be as frustrating.
Jun 23, 2008 | Nintendo DS Lite Console
Action Replay; problem starting
You need to reset the AR, just hold down A, B, select, and start when poering it on, hold them down until the "not liscenced" screen shows up. This will flash the memory on the AR and you will need to re-enter codes though
May 25, 2008 | Nintendo DS Lite Console
Action replay problems
Try resetting the hardware by following these steps: 1/ With the console powered off, hold A+B.
2/ Power up the console while still holding A+B.
3/ As soon as the Nintendo screen is displayed, before our screen stating this product is not endorsed by Nintendo, press and hold Start and Select while keeping hold of A+B.
4/ Continue to hold these buttons until the Main Action Replay screen is displayed, then release. Your product is reset, and will accept codes once more.
I do not have credit. these instructions were from codejunkies.com (creators of AR). then try uploading them on the computor.
Jan 20, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
223 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
