Question about Mitac Mio 168 Pocket PC
Hi My mio 168 wont get past the align screen no matter how accurate I touch the screen, it goes through the five crosses then starts again, has anyone any Ideas. Col
  • Colin Johnson Apr 20, 2009
    Hi Kingul, thanks for your input, I was hoping it might be a software prob,,.
    Col
  • 45 Answers
From my experience, the only solution is to change the display
Posted on Apr 20, 2009
What I have heard from someone who used to work with this company is that 99.9% its not a hardware fault but a levelling fault. The screen has a square metal plate that sits behind it and needs to be perfectly aligned with the touchscreen you see in front. Even 1mm slide would cause problems. They have the tools to reset it to factory "defaults". A simpler alternative is to use "Virtual mouse" from Innovisoft that provides a mouse cursor for guidance !
Posted on Aug 12, 2009
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
Mitac mio 168 problem
call the techie. That'll the best
Mar 25, 2017 | Mitac Mio 168 Pocket PC
Display problem mio 168
After battery changing is usually needed to reboot a device (on the side of the device).
firo
Sep 16, 2008 | Mitac Mio 168 Pocket PC
Mitac Mio DigiWalker 168, Pocket PC PDA w/ GPS
mijn probleem is dat ik deze pc/pda in het nederlands wil zetten hoe doe ik dat
Sep 09, 2008 | Mitac Mio 168RS GPS Receiver
Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Jan 18, 2008 | Mitac Mio 168 Pocket PC
Mitac Mio 168 won't go past ALIGN SCREEN
The touch panel on the LCD unit is defective and needa to be replaced with a new Compleet new LCD+TP unit.
If you have a screen gaurd on your Touch panel, try to remove it and check again, if it doean't help ---> new LCD+TP unit
Nov 15, 2007 | Mitac Mio 168 Pocket PC
Mio 168 and 169
Hi I think this link is what you need :: You can download the manuals from this site as well. http://www.mio-tech.be/en/support/168-manuals.php Have a great day!!
Apr 27, 2007 | Mitac Mio 168 Pocket PC
Mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
Jan 16, 2007 | Mitac Mio 168 Pocket PC
Broken screen
www.dg-kehao.com
please check this website you will get the replacement you are looking for.
if you want to ask something directly, please contact me: pda.lcd.china@hotmail.com
May 07, 2006 | Mitac Mio 168 Pocket PC
Mitac Mio 168 Pocket PC Logo
405 people viewed this question
Top Mitac Computers & Internet Experts
Alan Hohenbrink
Alan Hohenbrink
matt
matt
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
