Question about Roper RT21AKXKQ Top Freezer Refrigerator
The light stays on and the refrigerator runs, but it does not get cold. Moved refrigerator. Plugged in and let sit overnight. Fan ran continuously, but it never got cold.
  • woodworke177 Apr 23, 2009
    Not a problem anymore. It just needed to sit longer unplugged.
  • Robert Moller
    Robert Moller May 11, 2010
    Why is the light staying on ?
    Guru:
  • 1,524 Answers
You have a defrost problem.
Posted on Apr 23, 2009
Side by side refrigerator model MCD2257HES, has stopped working. The fan isn't running, nothing is cooling. I unplugged overnight, plugged in this morning.
Is the defrost timer out of sync? Usually it defrosts early in the AM. If you unplugged it for a long time you will have to set the time on the defrost timer.
Aug 08, 2015 | Maytag Refrigerators
CAN MY DOMETIC RV FRIDGE BE FIXED
try unplugging it and allowing it to sit for 24 hours or so to allow the refrigerant and compressor oil to settles. then retry. If the filter got plugged you will need a refrigeration tech to repair it.
Sep 04, 2014 | Dometic RM2652 Refrigerator
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Just got a used Avanti. We let it sit overnight due to laying it on its side to deliver it. It is not getting as cold as it should be and it has been running for 60 hours since we plugged it back in. I...
That is most likely the problem. It may be due to a failure of the fan itself, the thermostat or damaged wiring in transit.
Once you get the fan operating again, it should cool again.
Aug 01, 2011 | Refrigerators
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Fridge not working freezer works what should i do
see if you can hear the evaporator fan running in the freezer. if you can't you will need to replace it as this fan pushes the cold air from the freezer into the fridge to keep it cold.
Nov 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge or freezer are not cold
I had similar problem: condenser fan was running, but compressor was not. After I unplugged refrigerator for a while and plugged back on, the compressor ran for a few seconds. Compressor testing indicated it was OK, I suspected that it was either overload/relay or run capacitor. My limited testing equipment could not tell me which one was bad. I took out the run capacitor out of system by unplugging the 2 wires and the refrigerator ran fine. After Replacing the run capacitor with a new one bought from partselect.com, it ran fine so far.
Jan 16, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer and refrigerator run but is not cold
Remove the back panel at the bottom. The refrigeration system is a sealed system and the smell would not come from it internally. Check and make sure the fan motor is running. If the fan motor (was) shorted out it would account for the reseting of the breaker. After resetting the breaker a number of times would cause the circuit in the fan motor to open allowing the compressor to run. Is the small line coming out of the compressor hot? If so replacing the defective fan motor may correct your problem.
May 03, 2008 | Refrigerators
Roper RT21AKXKQ Top Freezer Refrigerator Logo
109 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
