Question about Encore SONNET /ST G4 1GHZ1MB L3 CACHE (732311002441)
Computer shut down message after installing Encore upgrade.
I have a Mac G4 450mhz AGP computer. I had brought a Encore/st G4 1GHz Processor to add some power to the computer. Now, everytime i boot up my computer i get a "you need to shut down and restart your computer " message. Anyone out there heard of this problem before and can help?
  • 8 more comments
  • seiya Sep 22, 2007
    Good sound advice! but for me retuning the item is not a choice I have.
  • seiya Sep 23, 2007
    Thank you. but this is a G4 AGP Graphics cumputer no jumpers.
    I have since re-installed the processor. the computer recognize
    the processor and iam able to stay on for a bit longer before it
    tells me to shut down also..now my applications are
    quitting out on me.
  • seiya Sep 24, 2007
    the G4 is more than able to handle this processor.thank you very much for your reply.
    Thank dyllan! The Fan is the only thing working fine on the puppy.
    the heatsink /fan/processor/ are all one unit.I have
    it in now as iam writeing this. I haven't had a shut
    down notice yet,but it will not load my external drive.
    Iam begaining to think PCEXPERT is right, i just have a bad product!
  • seiya Sep 25, 2007
    anyone else have a suggustion?
  • seiya Sep 26, 2007
    SparkGap thank you. But no Drivers Needed. No "SAfe Mode" in OSX.
  • seiya Oct 13, 2007
    THanks for your response. But no windows on a mac.
  • seiya Oct 15, 2007
    By "Swap" you mean I have a bad unit and I need
    to buy a new one?
    This is what i was hopeing to avoid
  • seiya Oct 17, 2007
    It happens after bootup.(i do not use log in )
  • seiya Oct 18, 2007
    First of all thank you very much for takeing the time to look at my problem
    I have a AGP Graphics mac., the Processor that i have comes with a fan and
    heatsink. Though I was told i didnt have to I made sure the firmware was
    updated before I placed in the new processor.And iam pretty sure I do not
    need the thermal paste. Again thank you for your time. I think i just got
    a bad product. iam going to buy a new one from the SONNET website, if this
    one doesn't work I can return it, and know its my computer that is the problem.
    thanks again for everyones help.
    Novelist:
    Champion:
  • 382 Answers
What you experienced, with the black vale drop down and directions to restart your computer in 5 different languages.
In the OSX environment this is called a Kernel Panik. Usually this is caused by hardware not communting properly with the processor,  mostly external- like firewire hard drives and what not. But internal conflicts result in kernel panics as well. A component on the logic board failing, bad ram, or yes failed processor upgrades. I would consider possibly investing in a MAC MINI. YOu would be abled to use your monitor, keyboard, and mouse-take up 1/4 the footprint, and 1/16 the space. Current ones are Intel based and are literally 6-8 times faster.
It might be time for an upgrade.
Posted on Oct 24, 2007
    Sergeant:
  • 274 Answers
I'm not a Mac expert but I did find your Mac went through 4 design changes.  What is the model number of your Mac?  This is important because not all models are upgradeable per another website.
  Quote:
Is the CPU on the Power Macintosh G4 upgradable? How is it mounted?
Officially, Apple does not specify that the processor on the Power Macintosh G4 series is upgradable, since Apple has no plans to offer upgrade cards for the machines. However, PCI-based Power Macintosh G4 models have the processor mounted on a ZIF, and AGP-based Power Macintosh G4 models have the processor mounted on a daughtercard with a 300-pin connector.
To determine whether your Power Macintosh G4 is PCI-based or AGP-based please refer to the specifications for the particular model of interest, and to the Technical & Performance Q & A section of this Q & A.
Also in my research I found references that the "firmware" may also need updating.  But that may apply to a different situation.
Posted on Oct 17, 2007
  • Jerry Hess Oct 17, 2007
    I did some more research and I see you may have done everything right.
    The Encore/ST G4 is 100% OS X compatible, and supports from Mac OS 9.2
    through OS X Version 10.2 (Jaguar). OS 9.2 may be required to perform
    Apple firmware updates.
    Is your OS 9.2?  You didn't state that. That may be you problem.
    I found this for you too and after reading it, it may be that when you installed the new processor the heat sink was not properly seated or the heat sink thermal paste was applied incorrectly.  This would cause over heating and shut down.
    http://www.macworld.com/2003/10/reviews/...
    Sonnet sets bus speed for you—so you don’t have to configure any annoying jumpers. But it doesn’t come with a heat sink or fan. You have to remove the heat sink that was attached to your original processor and attach it to the Encore card. While reinstalling the old heat sink isn’t difficult, you may have problems down the road.
    The Sonnet upgrade card comes with a thin layer of a creamy heat-conducting substance. Once the upgrade is installed and running, the pad adheres to the heat sink, efficiently pulling heat off the processor and dissipating it. But if you need to reinstall the original processor or decide to move the upgrade to another computer, the thermal paste pulls apart like peanut butter between two slices of bread. The documentation doesn't mention this, but you should go out and buy a tube of thermal paste if you plan on moving the processor to another system.
    And one last bit of information:
    http://www.sonnettech.com/product/encore...
    Mac Compatibility
    Power Mac G4 (AGP Graphics)
    Power Mac G4 (Gigabit Ethernet)
    Power Mac G4 (Digital Audio)
    Power Mac G4 (QuickSilver 2001)
    Power Mac G4 (QuickSilver 2002)
    Power Mac G4 (Cube) (1)
    Macintosh Server G4
    Technical Notes:
    (1) Power Mac G4 (Cube) supported by Encore/ST G4 product no. SG4C-1800 only; professional installation is highly recommended. Part numbers without a "C" are NOT compatible with Power Mac G4 Cube.
    This is about the extent of my help.  If any of the information I have given you in the last 3 post helped solved your problem, great.  Or maybe it was enough for some one else to recognize the problem too.  I hope I was able to help you.
  • 4,889 Answers
Do you get this after the logon screen or before?
Posted on Oct 16, 2007
  • eagle338
    eagle338 Oct 17, 2007
    Thats it..the problem is very simple..you did not re-install your OS after you bought the new processor...the operating system will be searching for the old processor and this is the cause for that message..Now the best thing you can do is boot from the cd and re-install the OS..
  • eagle338
    See this article it gives not only info on installing OS X but also mentions your error.."If
    you screw up and have to restart the machine, you can get the
    machine into a state at which it no longer works at all"
    It also explained how to fix it...
    http://resale.headgap.com/osxnotesG4.htm...
    Scholar:
  • 151 Answers
The Encore products are auto-configure to their host system. You need to swap the processor cards.
And it only supports Mac OS 9.2 and Mac OS X Version 10.4 and higher.
Posted on Oct 14, 2007
    Habit-Forming:
  • 188 Answers
Problem seem to like ur processor is ok u may have sone problem with windows...
i think after instslling a new processor u did not re install ur window .
i suggest to re install ur window first...
if it doesnt work then u should changr u r processor...
u r motherboard is ok..dont byrry about that...
ok
i hope u r problem will be solved...
best regards & best of luck..
Posted on Oct 12, 2007
  • 363 Answers
Is there a 'Safe Mode' you can boot into? It might prove that the processor is ok and that there is a driver problem.
Posted on Sep 25, 2007
    Sergeant:
  • 279 Answers
Next time it shuts down, as soon as it's finished disconnect the power and open the case, then gently touch the new processor... is it hot? It sounds like an overheating issue to me. The processor fan and heatsink, may not be sufficient to keep the system cool - or they might not be getting enough airflow from the case fans. It's also possible that you forgot to plug the processor fan back into the board, so it's not coming on. If the processor isn't hot, let me know and I'll see what else I can figure out to check. Also, if this heat sink is not the problem, please wait to rate my answer until I have another chance to look at what the problem may be. Thanks and good luck, Dyllan
Posted on Sep 24, 2007
  • John Goodman Sep 24, 2007
    It is starting to look that way. I'm not sure what else to suggest at this point.
    Scholar:
  • 68 Answers
What I would do before proceeding any further is check the specs of your processor. Compair them to what the manufacture of your computer says. If you are running a faster processor than what manufacture recomends you could be doing more harm then good. If you look on the website for your particular computer you will find technical data in the support section. This will give you a idea of what your maximum and minimum processor should be. Speed and cache is very important. Mother boards are designed specifically for a maximum processor speed and cache.
Posted on Sep 23, 2007
  • 752 Answers
Are there jumpers on the Motherboard that need to be changed to correlate the clock speeds?
Posted on Sep 22, 2007
    Sergeant:
    Champion:
  • 293 Answers
If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 21, 2007
SOURCE:
My cd tray refuse to open, I have a ibook g4, can you help ???
I want to upgrade my powerbook G4 :
processor 400 MHz Power PC G4
Memory 256 MB SDRAM
L2 Cache (perCPU) 1MB
Bus Speed: 100 MHz
I'm looking to upgrade memory and speed !!!
Nov 02, 2010 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Computer too slow to play song
Computer memory and processor speed are the things that make a computer too slow for music playback. Also check your system for routine maintenance. Use the Computer Cleanup utility in Windows. Although this will help, the system may not have enough memory or processor speed to playback.
Jul 31, 2010 | Propellerhead Reason 4.0 Upgrade - Windows...
Powerspec 8650. what type graphics card fits it? computer keeps shutting down while playing certain games on facebook. extra memory hasn't helped, so i think i need to upgrade my graphics card, just am not...
This card is listed for the model below yours.
Graphics Controller
  • Type AGP 4x - Plug-in card
  • Graphics Processor / Vendor NVIDIA GeForce2 MX 200
  • I would be looking for other causes of shut down such as overheating.
    Check that all fans are working and clean. Ensure all case openings / grilles are also clear.
    If you want to upgrade the vid card you can only get one with AGP 4X
    NOT 8X which most are now.
    Dec 21, 2009 | Micro Electronics PowerSpec 8650 PC...
    Automaticaly shuts off one minute after startup
    This usually due to overheating of the processor. The simplest thing to do for a start is to get several cans of compressed air from an office supply store and use short bursts of air to clear out the vents and fan grills. Give the inside of the cd slot a couple of blasts to clear out dust. If the computer runs for an extended time with a clogged heatsink it can actually bake the thermal grease off the processor.
    Oct 07, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
    Motherboard upgrade for Dell GX150
    If the motherboard you have installed accepts a socket 370 processor and you replaced the board, it would also have to be a socket 370 unless you were planning on upgrading the processor also. If you wanted to keep your existing computer case and other hardware, you might want to look for an inexpensive pentium 4 motherbard and processor to replace it instead of the pentium 3 you now have. If you get a new board that uses the same memory that you now have installed it would be a relatively inexpensive upgrade.
    Nov 29, 2008 | Dell Optiplex GX150 Tower Computer - 1GHz...
    CS3
    What is the processor speed on your powerbook? It needs to be 1Ghz or higher. CS3 will not run on a slower machine. That could be the issue.
    Jul 09, 2008 | Apple Power Mac G5 Desktop
    Processor upgrade digital audio g4
    dear devis
    it seems like u have damaged u r processor........
    go and conferm that by any computer hardware expert..(computer hardware shop near by u)
    best of luck
    Jan 06, 2008 | Sonnet Encore/ST G4, 1.8 GHz (SG41800)...
    Encore SONNET /ST G4 1GHZ1MB L3 CACHE (732311002441) Logo
    115 people viewed this question
    Top Encore Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
