Need schematic diagram of the washing machine assembly
Need to remove the steel drum of LG WF-T1031-TP. Have already removed the big center screw but the drum is stuck! Is there anything else to turn clock or anti-clockwise? Please help. I need to fix one side of the metal wall bottom of the washing machine as it is rusted!! If it gives away, I know I do not have any choise than to dump the beautiful washing machine!! Do you have any schematic diagram of the washing machine assembly - only mechanical one, not the electric circuit diagram. Thanks & regards, Rajesh
    Top Expert:
  • Washing Mach... Master
  • 43,031 Answers
A mechanical assembly diagram would have to be requested directly from LG.
Posted on May 18, 2017
SOURCE: Hotpoint WF865 Drum getting stuck?
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Posted on Feb 08, 2007
  • 159 Answers
SOURCE: Washing machine will not drain
The ball is part of the system. They float up when there is water in the washer and as it drains if go's down. It sounds to me you must have a blockage somewhere, if you know the pump is operating in the drain cycle. If your sure there is no blockage and the ump is working I would replace the pump. On electric pumps they may work but if the impeller is worn from something that got into the pump it will spin but not pump the water out. Hope this helps you.
Posted on Jul 12, 2007
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: i cant get the filter out of my washing machine help please
DO NOT keep trying to force the filter, especially not with pliers! Mine wouldn't turn, and when I eventually got it out it was because a coin was stuck in there! Rattle it left and right many times to free the coin, and eventually it will come out, but if you force it, either the plastic filter will break or the coin. Guess which?!
Posted on Oct 29, 2008
Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
watch the videos
Search Results
LG washer - Inner Tub Assembly replacement - Diagnostic & Repair ...
? 1:01
https://www.youtube.com/watch?v=vTKJFuKuUZg
Apr 30, 2015 - Uploaded by ApplianceVideo.com
WT1001CW LG Washer, Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos ...
ApplianceJunk.com - LG Top Load Washer Removing Bearing ...
? 4:17
https://www.youtube.com/watch?v=osTIeI7BIMI Dec 15, 2011 - Uploaded by ApplianceJunk
12:56. LG washer - Inner Tub Assembly replacement - Diagnostic & Repair - Duration: 1:01. ApplianceVideo ...
LG Top Load Washer Wash Plate Replacement #AGZ72909702 ...
? 1:39
https://www.youtube.com/watch?v=HBw4DvtrIjs Apr 11, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the wash plate on a LG top-loading washing ...
lg wf t652 washing machine remove drum Google Search
Apr 01, 2018 | Washing Machines
Can you remove the drum from lg fuzzy logic WF-T65T1 to get rid of mouldy smell
It is a big job. Why did you use vinegar and bicarbonate of soda? They cancel each other out. The drum is stainless steel, it can't smell. The smell is from mold on the rubber pipes and in particular the door gasket.
Put 2 cups of bleach in the machine and a couple of white towels or a load of white tea towels. Run the hottest wash for the longest time.
After you do a wash, dry the door seal and leave the door open for a couple of hours so everything dries out..
If it persists, get an engineer to replace the door gasket. Then keep it clean and dry.
Dec 18, 2017 | LG Washing Machines
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
How do you access between the drum and plastic outer casing? Trying to remove a bre wire from within.
remove the four screws that hold the whole top on two might be under plastic caps then you can see the ring which covers both bowls which is either clipped or screwed into place remove thatand you can then see
Dec 01, 2017 | LG Washing Machines
HOW TO REPLACE HALL SENSOR ON LG TROMM
Unplug machine. Remove back panel (4 phillips head screws). Remove large bolt in center of motor. Pull motor rotor off shaft. Remove phillips head screw(s) holding wire protector and possibly ground wire at bottom of motor area. Remove metric bolts from motor coils and remove coil assemble. Unplug 4 wire harness from Hall sensor. Unclip Hall sensor from coil assembly. Install new Hall sensor, and re-assemble. Plug machine back in. There. Done, and it only took 10 minutes!
Mar 27, 2011 | LG WM1814CW Front Load Washer
Our LG Tromm Washer is struggling to spin. Humming sound in the beginning and then displays LE on the panel. Heard it may be the Stator Sensor/Part. Any Advise please!!!
Definitely the Stator/Sensor/Hall switch. Go to http://www.mcminone.com and order part number 6501KW2002A (if your machine is model number WM2277HW). Remove rear panel, remove three retaining screws for sensor wires at left bottom of drum, remove drum outer retainer bolt in center, stator assembly is now exposed. Remove bolts holding stator assembly (I think there were six) and replace switch assembly by lightly prying tab locks off of stator. Press on new switch and reassemble...
Jan 23, 2010 | LG WM-2277HW Front Load Washer
NEED TO REPLACE REAR BEARING.GOT A NEW BEARING.NEED A DIAGRAM ON DISSASSEBLE,REPLACEMENT AND REASSEMBLE. OR SOME HANDS ON ADVICE....THANKS ..TY
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Oct 30, 2009 | LG WM-0532HW Front Load Washer
Laundry Center Washing Machine Leaks
Post the washing machine make and model, I see if I can find specifig diagrams for your appliance.
Sep 07, 2008 | Kenmore Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
LG washer wm1832c
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Jul 14, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
416 people viewed this question
Top Washing Machines Experts
