SOURCE: needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
SOURCE: Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
SOURCE: brother se 400 breaking needles
The needle breaks
1. The needle is incorrectly inserted
2. The needle clamp screw is loose
3. The is bent or blunt
4. The needle is too fine for the fabric being used
SOURCE: Brother XL 3500 needle won't move
there could be a broken or loose part in the machine, it needs to be serviced
