Question about GPS
Uniden hand held scanner
I own a uniden 50 channel programmable scanner. I do not believe i am picking up all the channels i have programmed into it. i was wondering if there is a proper way to input the frequencies so i may get the most satisfaction out of listening to my scanner?
  • Anonymous Mar 24, 2009
    Cannot set the channels the remote seems to be frozen
How do you changen the frequency?
Posted on Sep 21, 2008
My channels wont scan
Posted on Jun 13, 2008
SOURCE:
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
I HAVE A UNIDEN BC80XL HAED HELD SCANER RADIO. MAYBE IM STIPID BUT I CANT GET IT PROGRAMED FOR ANY FREQ. i NEED SOME REALL HELP THANKS
Your first step is to compile a list of active frequencies in your area. You can find a very good database at:
www.RadioReference.com
Next, mark or highlight the frequencies that you want to program, making sure that they will work with your scanner. See your scanner manual for a list of covered frequency ranges. The BC80XLT will hold 50 frequencies.
Once you have the desired frequencies, you're ready to begin:
- Power the scanner ON.
- Press the MANUAL key.
- Enter the channel number that you want to program (01 - 50). If you're going to program the entire scanner for the first time, start with channel 01.
- Use the keypad to enter the desired frequency, including the decimal point (e.g., 146.075). Zeros at the end of the listed frequency need not be entered (e.g., 805.25000 should be entered as 805.25).
- Press the E key to save your program information.
- Press MANUAL to advance to the next channel, then start by entering the frequency.
More detailed instructions are in the factory manual. If you don't have a copy you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Listening in since the 60's
Feb 08, 2011 | Uniden BC60XLT-1 Handheld Scanner
Hand held scaner
To enter a known frequency into the scanner's memory:
1. Power the scanner ON.
2. Press MAN to stop scanning.
3. Enter the number of the channel to be programmed (1 through 30) - OR - press the MAN key repeatedly to advance to the desired channel.
4. Enter the frequency including decimal point (ex: 146.25).
5. Press E to enter the info into memory.
6. Repeat steps 2 through 5 to program other channels.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Jul 05, 2010 | Uniden BC60XLT-1 Handheld Scanner
How do I program my Uniden Bearcat BC60XLT-1 Programmable Hand-Held Scanner
Press Manual, enter the channel number, then press manual again, enter the frequency you want including the decimal point, then press E to enter. If you make a mistake, press CLR twice to erase.....Get your frequencys for your state at www.RadioReference or www.RadioFreq.com hope this was helpful...
Apr 16, 2010 | Uniden BC60XLT-1 Handheld Scanner
How do i programme channels into my UBC73XLT uniden scanner plz
- Press HOLD to stop scanning
- Enter the channel number that you wish to program
- Press FUNC then PGM (Channel number will show)
- Enter the desired frequency, including the decimal point
- Press E to confirm
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com.au/resources_main/pdfs/UBC73XLT_OM.pdf
Dec 27, 2009 | Uniden BC72XLT Handheld Scanner
Need codes to program scanner that is a hand held Uniden Bearcat 30 channel 10 Band Radio Scanner
Frequencies for your area can best be found in databases such as:
www.radioreference.com
or
www.cityfreq.com
Sep 12, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
May 16, 2009 | Uniden BC340CRS Base Scanner
Want to scan cell band?
This non-trunking scanner made by Uniden can store 200 channels, and has a frequency range of 25-512mhz with some gaps in the broadcast bands. so cell phone is not possable
May 01, 2009 | Radio Communications
Realistic hyperscan400 channel
cant get channel codes for my uniden hand held
Nov 13, 2007 | Uniden BC60XLT Handheld Scanner
GPS Logo
90 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
