Question about Sony Ericsson W550i Cellular Phone
Charging error when i try to charge my phone, it says charging error, is the problem with my phone battery or with my charger?
  • Sony Ericsson Master
  • 19,396 Answers
That means that the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Posted on Apr 19, 2009
Hi. Sorry. My phone is i9300 when connected charger error is stopped charging battery temperature too high. Please help me. Tanks
check the battery composition you are trying to charge
some chargers will only charge lithium batteries and not charge nl.mh batteries as they charge too fast and over heat the battery
check the voltage of the charger as it may be incorrect for the battery
Jun 23, 2015 | Cell Phones
Phone is using more current than the charger is able to deliver
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 02, 2012 | Cell Phones
Phone will not charge
please post the problem clearly with full details like phone model/ actual problem (error message), what you have tried etc.
check the charger, some nokia phone deny the charging with duplicate charger, check the battery as the same is also a reason of non charging, incompatible battery will not charge in cellular, check the charger jack, if this all not work then you have toreplace battery connector or 47K resister (for nokia).
vote me if found helpfull.
Aug 04, 2011 | Cell Phones
I have been using Sony Ericsson K 790i for the past three years. While I am trying to charge the battery, it now shows a message, :Charging Error, Stop Charging". The battery is not getting charged at...
The battery could be worn out and needs replacing or the charging circuit in the phone is faulty or the charger is faulty.
Try another Sony charger to determine if it is faulty.
Then try another battery.
If none of these work then it may be cheaper to get a new phone on another plan..
May 30, 2011 | Sony Ericsson K790i Cellular Phone
Battery will not charge.Message reads "temp error charging stopped"
If you haven't already, try replacing the battery. If the error persists, replace the charger or test with another known, working charger. Else, the phone charging circuit must be damaged and the phone must be sent in for repairs or replaced.
May 16, 2011 | Cell Phones
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
Jul 17, 2010 | Sony Ericsson Z610i Cellular Phone
Motorola v325 won't charge after using phillips universal charger
Sometimes a bad charger can send a high voltage charge to the phone and fry the charging port on the phone. That is why a lot of the car chargers today have a fuse on them now. So that it will blow the fuse on the charger, instead of frying your phone's charger spot.
Dec 01, 2009 | Verizon Communications Motorola V325i...
Phone not charging properly
This is most likely going to be a charger problem.
I would suggest that you try charging the phone with another good, working charger of the same type.
If it charges it very well, then you can just buy a new charger for your phone.
But if it still shows the same error, try and change your phone battery and test it with another good battery.
One of these two is definitely going to be the problem.
Hope it helps.
Goodluck
Nov 16, 2009 | Nokia E63 Cell Phone
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Battery
If you tried to make a charger you could have damaged the Pinout or even the charging port on the phone however 99% of the time this common error with razrs is fixed by trying a different battery and or a different charger.
Jan 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson W550i Cellular Phone Logo
120 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
