Question about Cameras
Contax G2 shutter release won't depress or focus. Film loads, lights come on.
Contax G2 shutter release won't depress, film loads, advances, lights come on in viewfinder.
silly girl
  • 513 Answers
SOURCE: No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Posted on Jun 04, 2006
  • 19 Answers
SOURCE: Canon G3 irresponsive Shutter & non-see through viewfinder
optical view finder. this seams odd as it is only a lens. Was the camera dropped at some point? that may explain both issues. if not then I need to know a little more prior to offering an opinion.
Posted on Jul 09, 2007
  • 619 Answers
SOURCE: Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Posted on Feb 19, 2008
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
cammedic
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank...
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
May 10, 2011 | Pentax ME Super 35mm SLR Camera
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery...
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Apr 16, 2017 | Olympus OM-4TI 35mm SLR Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
Nikon fm10 cannot get shuuter release button to depress or film advance lever to work. is there a lock on shutter release ?
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Oct 13, 2009 | Nikon FM10 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
No shutter/film advance
with electronic cameras, it is the control circuitry. send it for service. your service agent probably will replace the complete pcb as they don't know or wouldn't care to diagnose which minor component went wrong.
pc-cook.
Nov 15, 2007 | Contax ST 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
