Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Unable to connect to internet
As i had d-link router model no dir-300 ,i am unable to connect to the inter net ,enen i am unable to log in to d-link site whatever the ip address u had given on the back of the mode say 192.168.0.1. and as i log admin user name i am unable to log to dlink web page.
  • D-Link Master
  • 32,281 Answers
The IP address 192.168.0.1 you use with your browser is not to get into the Dlink WEB page, it is to get into the DLink router configuration, to set up the router and wireless security eg. network SSID, turn off SSID brocast, WEP/WAP encryption, MAC address filtering etc.
Posted on Apr 19, 2009
How do I find my WEP key for D-link DIR-815
Hi
Reset the router to factory default IP & password with switch / pin hole on back. Use the factory Router IP address & pw to log in to the router using a Browser (Safari, FireFox, Opera, IE, etc) Change settings to whatever you want.
Note: we don't use WEP any more because it's not secure. Use WAP2.
Trevor
Sep 06, 2014 | D-Link DIR-615 Wireless Router
Log in
Open your web browser and type in the IP address of the router (192.168.0.1 by default)
The default user id is: admin and the password is left blank. Once you get into the router go to the wireless setup or tab.
Below is a pdf manual of your router.
ftp://files.dlink.com.au/products/DIR-300/QuickInstallGuide/DIR-300_A1_QIG_v2.00.pdf
Jun 02, 2012 | D-Link DIR-300 Wireless Router
I want to configure my router through web,but i ca not connect at 192.168.0.1 web address..
The default IP for the DIR-300 is 192.168.0.1. First, make sure you're entering "http://192.168.0.1" in your browser's address bar. In some browsers, if you try entering just the numbers, it won't work.
If you can't access the setup page at all, that address may have been changed. If this is the case, or you can't log in because you don't remember the username and password, you should reset the router which will restore the factory defaults.Press the recessed rear-panel reset button and hold it in for 10 seconds. Release it and the router will restart. The defualt IP (192.168.0.1) and username and password (both admin) will be restored.
Aug 16, 2011 | D-Link DIR-300 Wireless Router
When i plug in my router the ip address changes and i cant access net
This issue is possibly due to a configuration problem
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Here is the link for the DIR-330 your model number did not list:
http://www.dlink.com/products/?pid=564
Jun 21, 2010 | D-Link DIR-300 Wireless Router
Fails to connect
try to reset by pushing the button in the back then run the setup wizard by accessing your routers page via the ip address if you do not know your routers ip address plug it into your computer with an ethernet cable open up your command prompt and type in ipconfig then enter and look for your default gateway
Mar 28, 2010 | D-Link DIR-300 Wireless Router
Static IP address, primary DNSand Second DNS
hi
the router ipaddress or default gateway will be 192.168.0.1 and you can use any ipaddress from 192.168.0.2 to any... for your devices like computer and primary dns address will be 4.2.2.2 and the second dns will be 4.2.2.3
gud luck
thanx and regards
sukhvinder
Aug 18, 2009 | D-Link DIR-300 Wireless Router
I have activated the nat mode of my dlink dir-300 now i cant open the log in page by entering the ip 192.168.0.1
check the IP of your computer by going to dos: Run -> CMS -> then type IPCONFIG. If your IP address is not in the 192.168.0.X range then you will not be able to access it. You may have the IP assigned by the ISP or you may have to renew the ip address by restarting your computer. You can use another computer see if gets the 192... range or assign an IP belonging to that range manually.
Jul 30, 2009 | D-Link DIR-300 Wireless Router
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
460 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
