Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Dehumidifier automatic on and off function not working
Model Number AD 70 USV
On April 14, 2009 I bought the Whirlpool 70 Pint Dehumidifier from Canadian Tire.
I placed it in our finished basement with lots of space around it, installed a hose, started the unit and it seemed to be working properly.
Since wet spring weather has not really got underway, the basement is still fairly dry.
But since I turned the unit on and set it at normal and auto, it hasn't stopped running. I shut it off manually until the humidity rises and then manually start it again.
The unit reduces the humidity to 40% and continues to run.  Is 40% humidity considered normal and if so, why doesn't the machine shut off?
The unit has an automatic on and off function that so far is not working.
What needs to be done to correct this problem?
Thanks for your help.
  • Anonymous May 19, 2009
    Mine doesn't shut off either.
  • 787 Answers
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Posted on Mar 10, 2017
MNTECH
  • 1543 Answers
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Posted on Sep 01, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: What is the proper humidity control % setting?
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
Posted on Feb 09, 2009
  • 148 Answers
SOURCE: Delonghi dh400p dehumidifier error e1 with ice
was the filter dirty that will do it let it defrost and put it back on
Posted on May 17, 2009
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Posted on Jul 20, 2009
  • 41 Answers
SOURCE: what percent setting do i put my kenmore 50 pint
Try 50%.
Posted on Oct 06, 2009
My whirlpool AD70USS 70 pint dehumidifier won't run , it just beeps. There is power and the bucket is in place properly, The unit is clean and nothing is plugged and the fuse in the panel is ok
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Compressor not working on dehumidifier
heatman101
Nov 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Whirlpool Gold dehumidifier that's about 5 years old. The motor sounds and runs just fine, but it's no longer collecting water. Is it fixable?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Machine is not withdrawing water.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
heatman101
May 03, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
430 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
