Question about Sony Audio Players & Recorders
What voltage drives the Sony PS-LX49P turntable ,for use with other equiptment
  • 1,029 Answers
Turntables Usually Work Out Fine With A 12v Dc Power Supply.
But You Have To Check What Is Ground And What Is The Positive Supply. check For Ground With A Multimeter To The Platter For The Negative. Other Things To Look For Is It A Ribbon Connector
Or A Dc Power Jack From The Turntable,and The Signal Leads. hope this helps
Posted on Apr 19, 2009
  • Ari Dee Dec 31, 2012
    Hi, I have 2 adaptors, one is 12V 500mA, and the second is 12V 1.7A. which one should I use?
Sony LBt-d307 user manual
I could find the HST-D307. Just with Google and it was the first hit.
Should be the same manual as for the LBT, but I can't see that.
http://diagramas.diagramasde.com/audio/HST-D307%20Service.pdf
Jun 26, 2014 | Sony Ps-lx49 / Ps-lx49p Stereo Turntable...
Sony Turntable PS-T33 stops turning
first check if its loosing elasticity in the belt or coming over, you want the belt to be in good condition and not worn out. after checking that you also want to check the mechanisms that drive that and check voltage on psu
Mar 01, 2013 | Sony Audio Players & Recorders
I need a diagram to re-install belt on Sony turntable PS-LX250H
I'm sorry for the difficulties you're experiencing in installing the drive belt. Please click hear to get the instructions to install a drive belt. Please click on the sub links on the page to view the diagrams.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 01, 2011 | Sony PS-LX250H Turntable
My Sony PS-LX250H Turntable suddenly started playing records too fast for both 33 and 45 speeds. Any ideas on how to fix???
If this is a belt drive then most of these speed increases are caused by the belt being in the wrong position. The belt could be faulty and my need to be replaced. Otherwise it could be due to a power supply problem, such as a faulty regulator to the supply of the motor. A check on the voltage to the motor will determine this. Assuming you know what the correct voltage should be! Of course with luck it will be higher than the motor is supposed to run at.
Feb 02, 2011 | Sony PS-LX250H Turntable
I received a SONY PS-LX250H turntable with the drive belt off. Where do I route the drive belt to get it back on?
The Operating and Install Guides are here...
http://www.retrevo.com/support/Sony-PS-LX250H-Turntables-manual/id/752ag608/t/2/
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C310321&fes=true&mdl=PSLX250H
Follow this procedure to install the belt on the turntable.
  1. Lift up on the dust cover [FIG. 1] and remove it from the turntable base [FIG. 1].
  2. Remove the rubber mat [FIG. 1] from the platter [FIG. 1].
  3. Lift the platter straight up off the spindle [FIG. 1].
  4. Slip the drive belt around the under side of the platter [FIG. 2]. IMPORTANT: Line up the ribbon that is attached to the belt with the square opening near the edge of the platter .
  5. Place the platter back on the spindle .
  6. Spin the platter so the square opening on the platter is over the motor pulley [FIG. 1].
  7. Stretch the drive belt [FIG. 3] over the motor pulley by pulling the attached ribbon [FIG. 3].
  8. Remove the ribbon from the drive belt .
  9. Reinstall the rubber mat and the dust cover .
Jan 29, 2011 | Sony PS-LX250H Turntable
Drive belt has fallen out of sony ps lx 300 usb and i need to reroute it
hi,
watch the following video to install the belt on ur player. same for all belt driven turntables.
utube.png You-Tube video "uip28-HKUj4&feature=player_embedded#!" placeholder
Jan 13, 2011 | Sony PS-LX300USB Turntable
I am assembling a sony turntable and don't understand step 3. Using the ribbon, loop the drive belt around the motor pulley. PS-LX300USB model Thanks
Manuals and belt instructions here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=PSLX300USB&LOC=3
You would handle the belt by the ribbon instead of bare fingers so your finger oils wouldn't contaminate the belt. You stretch the loop of the belt over the drive pulley between the flanges to hook it.
Nov 07, 2010 | Sony PS-LX300USB Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
1,474 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
