Keys wont unlock or lock doors and the ignition doesn't turn. I have tried all 3 of my keys, one is the wireless key, which says doesn't recognize. The alarm went off the day before with car unlocked and key inside. Couldn't get it to stop by unlocking the doors or putting the key in the ignition.
SOURCE: key wont turn in ignition
try wiggleling the key too the tumblers may be getting worn in the ignition is this works then replace the ignition
SOURCE: my renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
SOURCE: c240 mercedes key wont turn seems locked
I have a 2001 C240 with the same issue. I removed the positive battery cable from the battery and kept it off for 30 seconds then replaced it. Everything was reset and the key worked.
SOURCE: car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
