Question about Belkin (F5D7230-4) Router (587009)
Connected to network, but can't load webpages
Heya there,
I am connected to my wirless network and everything works just fine (e.g. talking on msn and playing Call of Duty on the PS3), but not for loading up web pages. It says 'Address Not Found' and i have refresh several times before it is up and running.
I have a Belkin router and a few days ago resetted the router settings (password and the SSID). Before i changed the details, everything was working perfectly.
jessee007
  • 310 Answers
SOURCE: Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
Posted on Jan 08, 2008
Bat1956
  • 585 Answers
SOURCE: belkin wireless router not assigning IPs for wireless clients
Some routers start handing out DHCP wireless IP's at 192.168.2.100. Try setting the upper limit at .110. If the router is found in a site survey (view wireless networks) but cannot connect, the limitation would be why.
Posted on Jan 10, 2009
Tom Marvolo
  • 708 Answers
SOURCE: My laptop detects my network connection, I click
Open RSP By typing 192.168.2.1 on the address bar of the internet Explorer
On the Left side Click on WiFi Protected Setup ( If its v 5000)
Leave the password blank and click submit
Disable it and click apply changes
It May Work
Posted on Jan 07, 2010
tknalty
  • 121 Answers
SOURCE: I've been having trouble loading some pages pretty
After carefully considering the problem, if you are saying that your computer loads the pages perfectly (fast and clear) when it is set up directly to the modem, then it has to be the Wireless component of either the Modem itself or your Computer.
It can also be interference with other wireless gadgets within the home.
If it is a Laptop you are using, you may wish to purchase a Belkin wireless booster to boost the signal.
If it is a PC Desktop you are using and there is no reason that it can't be connected via an ethernet cable, then I would suggest connecting it directly.
Ethernet cable is shielded cable which is designed to omit interference.
Whilst wireless is great, it is not always the answer (especially if there are other devices which are conflicting with the signal).
I hope this information is useful. Regards,
Posted on Feb 10, 2010
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
Jul 01, 2011 | Siemens Efficient Networks SpeedStream...
Cannot connect to internet. Wireless connection indicates it is working, but Internet Exploer indicates cannot display the webpage.
This is usually because the wireless key code (password) was entered incorrectly or has got corrupted. Go to "view wireless networks" (from the icon at bottom right of your screen) find the one it says it is connected to and click "disconnect". Then re-boot the PC (not strictly necessary but a good precaution), go back to "view wireless networks", find the correct one for your router and connect to that with the correct code key. I have seen it where the code key has been changed from the one written on the sticker on the router and if that is the case the "fix" will be more complicated.
Also, if this does not work, go to "control panel" then "Internet options" and then "advanced" and find and click on "reset". This puts Internet Explorer back to the default settings and often fixes it (though NOT if yours is an incorrect wireless key issue as talked about above) - Your home page will change to MSN but that is easy to change to your preference.
Hope this helps
John B
Jun 10, 2011 | HP Compaq 8510p Notebook
Your computer is not connected to the network when cam talk
In order to use the video call feature both parties have to be in Yahoo Messenger 10.
If you both have Yahoo you can use the webcam
If you are cross chatting - eg Messenger X MSN, only basic IM will be available
Jan 12, 2010 | Yahoo Messenger
Many websites are not loading. MSN, Microsoft, etc.
There are a few ways to get this going again.
Goto your control panel;network places;show network connections
Right click your connection, disable it, unplug the power cord from the modem itself for 10 seconds, click the reset button on it, plug it back in, enable the connection, repair.
You can also go into your command prompt.
start;programs;accessories,command prompt
type:
ipconfig
You should see 3 sets of numbers- IP address, subnet mask, and default gateway. If all the numbers are zero, that's a problem!
type this next, remember to have a space before the forward slash:
ipconfig /release_all
after that
ipconfig /renew
Try connecting and let me know what happens
Apr 08, 2009 | Actiontec Computers & Internet
Unable to connect to internet
Try going to command prompt and type ipconfig /release
Then type ipconfig /renew after the IP is released. If you like, I could remotely connect and troubleshoot it for you.
Jun 24, 2008 | Dell Dimension 8200 PC Desktop
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless router connected and everything enabled but still says not connected
You said the wireless connection is disable, Did you enable it already by right clicking on it and selecting enable?
May 08, 2008 | D-Link Wireless
Internet Explorer
goto the tools menu within internet explorer and choose "internet options" tab Then go to connections tab. once your there then click on lan settings. Once there make sure "Automatically detect settings" is checked. close internet explorer and then open again and problem should be solved. I
Thanks
Todd
Laptop Guy
Apr 21, 2008 | Dell Inspiron 6400 Notebook
Belkin (F5D7230-4) Router (587009) Logo
193 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
